Click Here
Wheels with Right Stuff Brakes
Old May 16th, 2014 | 01:38 PM
Boilerz25's Avatar
I have the front disc conversion kit for the 1969 442 from Right Stuff and I was wondering if the stock 14" SSII wheels will mount over the discs. Do I need a 15" wheel to accommodate?
http://www.getdiscbrakes.com/afxdc01c
Sean
Old May 16th, 2014 | 05:51 PM
Sean
Once again, ALL SSII/III wheels of any factory-available diameter or width will clear factory disk brakes. If your conversion kit uses repro stock spindles, caliper brackets, calipers, and rotors, yes the 14" will fit. My 70 W-30 came from the factory with disk brakes and 14" SSII wheels.
Old May 16th, 2014 | 07:16 PM
70cutty's Avatar
Beer Connoisseur
I thought there is a difference between 14" wheels on drum brake and disc brake cars
Old May 17th, 2014 | 09:19 AM
This topic has been covered many, many times, but to refresh our memories, in the early 1960s, GM used 14" wheels that were contoured on the backside to clear the 9.5" drum brakes. When disk brakes first appeared on the 1967 A-body cars, these wheels did not clear the calipers, requiring the development of new 14" wheels that were contoured to clear the disk brakes. This is why through the 1970 model year, you will find drum-only and disk-brake 14" wheels, including the early SSI wheels.
HOWEVER, as we've discussed previously, ALL SuperStock II/III wheels ever made by Oldmobile, including the 14x6 versions from the 1968-69 model years, are designed to clear the factory disk brakes, which is what the O.P. asked.
Old May 17th, 2014 | 09:44 AM
70cutty's Avatar
Beer Connoisseur
I think I confused SS wheels and steel wheels. Thanks for clarifying that.
Old May 17th, 2014 | 05:39 PM
Boilerz25's Avatar
Thanks Joe. I realize wheel brake fit has been discussed plenty just wasn't sure with the Right Stuff kit. Thanks for the feedback.
Sean
Old May 17th, 2014 | 05:46 PM
Sean
This is why I'm always careful to add that the wheels clear factory (or exact copies of factory) disk brakes. Now, I just bought spindles, caliper brackets, and backing plates from Right Stuff at Carlisle for my 64. I'll be using parts-store rotors and calipers (though, apparently not Cardone calipers... )
72OldsRocketMan
April 18th, 2014 04:28 PM
coldfire
Suspension & Handling
July 25th, 2013 04:30 PM
kitfoxdave
Brakes/Hydraulic Systems
15
March 28th, 2013 09:19 AM
rkk69olds
April 26th, 2012 11:11 AM
doc
April 11th, 2012 09:25 PM
