Click Here
Two questions re 1950 Olds 88
Old Feb 9, 2013 | 10:03 AM
Evans1's Avatar
Can anyone educate me re:
1. What size bias-ply tires came stock on the 1950 Olds 88 Club Coupe?
2. What is the largest size radial tire I can run on this same car without any rubbing or other issues?
Thank you! Evans
Old Feb 9, 2013 | 11:42 AM
stetzie's Avatar
stetzie
50 Olds Tire Size
As I remember it, 710X15 was a stock size from the factory, for the cheaper models.
760X15 was the next step up, 800X15 and 820X15 were usually found on the 98's of the day.
This was a long time back for me, but I believe these sizes to be correct.
Others may be able to correct if needed.
stetzie
Old Feb 9, 2013 | 02:17 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I would call Coker Tire or Diamondback and check on the radials. I have heard stories about running radials on those early rims but don't know if they are true or not. It is worth asking about.
Old Feb 9, 2013 | 02:21 PM
Evans1's Avatar
Good advice. Thanks, Evans
golds56
Mar 9, 2012 10:53 PM
golds56
Nov 4, 2011 03:09 AM
Dutch
Ninety-Eight
27
Oct 25, 2009 07:26 PM
Oldsguy
Oct 13, 2008 11:41 AM
Terry S. Hodges
Jun 2, 2006 05:20 AM
