Click Here
Need help with lug pattern + wheels - 1964 NinetyEight
Old Nov 14, 2022 | 01:49 PM
nspec's Avatar
Hey guys. I upgraded all 4 brakes to disk in my 64' Ninety Eight.
The OEM small wheels do not fit any more.
Anyone know the exact lug pattern of the car?
Also recommend a place to buy some cheap/temporary wheels to roll the car around in?
Old Nov 14, 2022 | 02:45 PM
rocketraider's Avatar
Oldsdruid
5x5 bolt circle. If 15" wheels will clear the disc setup, wheels from any 70s GM pickup or full-size car will give you a means to roll the car around. Also 1980s GM full-size wagons.
Curious how you did the fronts. Scarebird has had a bolt-on kit for the 57-64 rear for years but the front often required machine work on the spindles.
Old Nov 14, 2022 | 02:54 PM
Don R.'s Avatar
If you want good heavy duty wheels get a set of cop wheels from a 94-96 Chevy 9C1 police car. They are 15" by 7" and should clear disc brakes easily. I actually have a set of five that I used on my 63 Starfire if you are interested...
Old Dec 6, 2022 | 08:17 PM
nspec's Avatar
Thank you! I'll look more into them soon. The shop doing a motor swap on it did the work for me. I remember ordering the kit from a site few years ago. It was not easy and they had to swap several parts to make it work.
Thank you! I sent you a PM.
Dusty72
Wheels and Tires
Aug 6, 2022 04:14 AM
Roger60
Wheels and Tires
May 10, 2017 06:30 AM
JasonB
Suspension & Handling
Oct 9, 2012 07:06 PM
olds70supreme
May 14, 2012 06:15 AM
64 Olds Dynamic 88
Apr 28, 2008 08:23 AM
