Click Here
View Poll Results: Stay as is or wider RWL tires?
Current tires
12.50%
BFG Wider RWL's
62.50%
Something different
25.00%
Voters: 8. You may not vote on this poll
Keep the current front tires or go BFG RWL's all around?
Old Sep 20, 2016 | 08:47 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
My current 205/75R14's on the front are nearly new. They handle fine but are skinny and the front end sits higher than the back. I was thinking of 235/60R14's on the front, current back tires and 245/60R14's on the back. Just not sure if the $350 is better spent elsewhere.
Old Sep 21, 2016 | 05:49 AM
IMHO you should put white letters all the way around or black walls all the way around. Mixing them looks odd, but it's your car do what you want.
Old Sep 21, 2016 | 06:59 AM
I agree, if you want to replace the rears, just install them with the rwl's inward. You can always reverse them down the road when you replace the fronts..
Old Sep 21, 2016 | 09:28 AM
I can always go white paint marker on the front lettering as well, would look good. The rear tires are 25" tall, the front are 26" tall. If I went 245/60R14 on the back, the height would be one inch lower in the front. Not sure if filling in the wheel well and lowering the front a bit is worth $350 when there is nothing wrong with my tires. An inch might do the trick, thinking it was only 1/2".
Old Sep 21, 2016 | 10:35 AM
All of your suggested options are too small in diameter. If you want to keep the 14" wheels, then 225/70-14s will look the best at 26.5" in diameter. The tallest 60 series tire available today in 14" is the 245/60-14, and that's about an inch smaller in diameter than the 225/70s. Anything smaller belongs on a Civic.
Old Sep 21, 2016 | 10:48 AM
70-442-W30's Avatar
344879M363895
I would just go with whatever Joe says on this because he really knows this topic (and pretty much every other one.) When I got my AR wheels and tires before, I should have just went with what he said. Although they looked ok in the end, they didn't match the car that well. It can end up being an expensive mistake.
Old Sep 21, 2016 | 11:00 AM
If I needed all four I would agree with Joe. Maybe my body work made the wheel openings even wider looking. The 245's also work with my current speedo gear in my planned 2004R swap.
Old Sep 21, 2016 | 12:25 PM
Not really sure that saving $10 on a speedo gear is the best reason for picking those tires...
Old Sep 21, 2016 | 12:37 PM
ELY442's Avatar
X2, that's what I got on my 70 Cutlass convertible.
Old Sep 21, 2016 | 12:52 PM
lshlsh2's Avatar
71 cutlass convertible
At some time you might want to bite the bullet and get 15 inch rims and tires. I know way more money but the lack of choice in 14 tires. That is what I am doing. my .02
Old Sep 21, 2016 | 03:49 PM
lemoldsnut's Avatar
I run 235 60 T/A radials and rotate them as needed. Works well for me
Old Sep 21, 2016 | 06:21 PM
Ely442, what size is on your 70 S? Due to fender differences, skinnier tires look OK on the convertible. Joe it also means I need to swap the driven gear which can be a bitch. $300+ up here for a pair of BFG TA's, need 4 vs 2 unless keep the 235/60R14's on the front, which would look stupid.
Old Dec 30, 2018 | 04:41 PM
Onit's Avatar
Comet and a regular scrub brush.
Old Dec 31, 2018 | 05:16 AM
I almost about this poll. Car currently looks like this.
But I may paint these to body colour and add trim rings and put these back on.
Old Dec 31, 2018 | 08:25 AM
RetroRanger's Avatar
72 Olds CS
I like the alloys better than the dog dishes!
Old Dec 31, 2018 | 09:48 AM
They are nice, I have to agree. I currently have the dog dish rims on my 88 Cutlass Supreme Classic Brougham. Those Alloy rims are the factory 88 rims. I plan on doing a bunch of body work on 88 this winter and painting it Purple once weather turns nice enough. I may leave the rims black and just add trim rings or they may turn purple but staying black is easier to maintain and swap as I like.
Old Dec 31, 2018 | 10:14 AM
The alloy rims look good IMHO. Let us know what you do.
Old Dec 31, 2018 | 10:24 AM
76olds's Avatar
Hookers under Hood
Even thou I wasn't happy with my last set of BFG rwl tires, disappointed me due to the yellow tinge coming through the lettering. Having said that, I would probably buy another set just because I have ran them for the past 35 years or so with no issues on the 70's and 80's cars I've owned over the years.
If it were me, I would probably hold out for a nice set of 15" rims and leave the alloys seen in your avatar pic.
I think it looks nice as it is , I would put my money on something else and look for kijiji deals on rims and tires over the winter.
If you keep it at 14's , I myself would run 245/60/14 on rear and 235/60/14 front if you don't plan on rotating them , If rotating , I would go 235/60/14 on all 4 corners with the BFG RWL.
Eric
Old Dec 31, 2018 | 01:57 PM
I have 3 SS3 15" rims. I should have had 5 but some bastard stole two off the car before I bought it. It was a 76 Olds Cutlass, good 350, near mint interior, which I sold for $200. I used the 350 in the Olds powered 4x4 and only paid $50 for the whole car but it still sucks, one rim short. I just bought 4, 15" Monte SS/Camaro rims that I may Oldsmobilize them. I will probably leave it as is for now but it depends on how much I like the basic wheels with the stainless outer trim rings, only $50 for a set of 4. I did realize, I need to stop buying **** and buy a storage shed. I have did a major clean out and could hardly fit my Dakota in.
droldsmorland
May 27, 2019 05:08 PM
Don Roberto
Wheels and Tires
Jan 3, 2017 05:40 AM
nelsontj
Jul 24, 2014 05:49 AM
motor
Jul 10, 2013 03:21 PM
Miles71
Wheels and Tires
21
Jun 4, 2013 03:28 PM
