How is the Jack Bracket on 1968 Cutlass S secured to the trunk floor?
Does anyone know how the stock bracket with wing nut to hold the jack in place on a 1968 Cutlass S was secured to the floor of the trunk? Was it bolts and nuts that went right through the floor or self tapping screws, anyone know? Thanks....Todd
Well the pic that Alan put up would have the same type of bracket no matter what car was built IIRC. The difference is that SS wheels would have a shorter hook thread that was used with a special lock down nut. Also the jack handle would have 2 clips that hold the handle in place - on the sloped edge just inside the trunk.
If you have something other than what Alan posted in his pic, someone may have replaced the floor pan and not installed the hook bracket properly?
I'd be really careful about that. Have a look under your car and see what's directly under the hook latch on the trunk floor. Hint: rhymes with gas tank. Be safe; can you stop by a muffler shop or something and just have them tack weld the latch in for you? MUCH safer.
The bracket actually has two holes for where it is supposed to be attached. It is just to the right of the gas tank I've already looked. Thanks for the heads up though, two heads are always better than one.
jstrits
February 7th, 2016 11:33 AM
