Click Here
GM wheel differences?
Old Apr 9, 2015 | 09:02 AM
Catalina67's Avatar
Nooooooo! The measurement of a bolt CIRCLE is the diameter of a circle that passes through the center of all the wheel studs. If the pattern has an even number of studs, then yes, you can simply measure the center-to-center distance of two opposite studs, which is the diameter of the circle. A five bolt pattern does not have two opposite studs. Through a happy coincidence of geometry, on a five-bolt pattern you can measure from the center of one stud to the outside edge of the third stud and come close, but this measurement can vary based on the stud diameter, so at best it's an estimate.
You might want to look again. The 5 x 5" circle is shared with LOTS of popular cars and trucks, including the 1990s Impala SS and many half ton GMC and Chevy pickups. There are thousands of aftermarket wheels available with that pattern. Fitting behind the skirts is simply a function of picking the correct width and offset. Some wheel vendors offer a wide selection, some don't.
On my 67 Pontiac Catalina I bought a set of 14x6 wheels off of a 68 Buick delta 88 and my Pontiac hubcaps won't fit on them. Am I doing it wrong or does Pontiac hubcaps not go on Buick wheels even though both gm and both same size?
Old Apr 9, 2015 | 09:08 AM
Welcome. I moved your post to it's own thread because you'll get a better response than hijacking a thread that's been dead for five years, plus your question really isn't related to bolt circle.
In any case, hubcap fitment depends on how the hubcap is attached to the wheel. In the 1960s especially, GM often used wheels with special hubcap retention features that were not common across divisions. I cannot speak to the Pontiac wheels, perhaps someone here will have more experience.
Old Apr 9, 2015 | 01:02 PM
rocketraider's Avatar
Oldsdruid
Are you trying to use dogbowl caps or full wheel covers? Full covers should fit any 14" wheel from about all car brands.
Buick used some odd dogbowl retention schemes over the years; some years had clips, others the Buick dogbowl snapped into the bolt spider like a Chevy Rally wheel cap.
But the biggest thing is that Buick invariably used 15" wheels on their 60s full-size cars, so if you're trying to use 14" Pontiac wheelcovers it simply will not work.
Old Apr 9, 2015 | 01:12 PM
Buick didn't make a Delta 88.
And I'm not sure about the 14" wheels, but on 15" wheels, hubcaps for the small bolt circle won't fit large bolt circle wheels, and vise-versa.
Old Apr 9, 2015 | 02:06 PM
Catalina67's Avatar
I meant to put Oldsmobile not Buick and thank you everyone for your input
Colorado Olds
Feb 2, 2009 06:43 AM
muad
Jan 19, 2009 03:55 PM
Lady72nRob71
Dec 14, 2008 04:51 PM
musicars
Aug 19, 2008 11:02 AM
texasred
Jul 31, 2007 11:33 AM
