Click Here
American Racing Wheels on 68 Cutlass Supreme
Old Jun 5, 2010 | 11:04 PM
yeahbuddy's Avatar
I need some help with tiring sizing. I just bought a set of 4 American Racing Outlaw II rims in great condition for $120. They are 15 x 8 and 5 on 4-3/4 with a 3.75 back spacing. I am going to be throwing on some BF Goodrich Radial T/A's which I will be ordering from Tire Rack. What size tires can I get away with? I want wider tires on the rear. As of right now I am thinking 215/60R15 on front and 245/60R15 on rears or 225/60R15 front and 255/60R15 rear.
It is going on a 68 Cutlass Supreme. Drums all around. Any advice is appreciated thanks.
Old Jun 6, 2010 | 05:25 AM
70 cutlass s's Avatar
I don't think the 215/60 will work on the 15x8 rim. A 235/60 would work better on the rim. Then you can go 255/60 or 265/60 in the back. I like 275/60 in the back.
Old Jun 6, 2010 | 12:33 PM
yeahbuddy's Avatar
I am running the original wheels/hub caps right now which are 205/70R14. They are cracked from being dry and too narrow which scares me when I am driving at around 50-60mph.
My main concern is the wider tires not fitting correctly in the rear. Will 255 or 265 clear the back without sticking out further than the body? Looking to have it tucked in nicely with a fitted aggressive look. I am not sure what combo to go with.
Old Jun 6, 2010 | 02:25 PM
https://classicoldsmobile.com/forums...tml#post180931
Old Jun 6, 2010 | 02:44 PM
yeahbuddy's Avatar
thanks for the link
Old Jun 6, 2010 | 05:14 PM
OLD SKL 69's Avatar
GM Enthusiast
I have SSII rims on my Cutlass, all 15x7. I have 235/60 on the front and 255/60 on the rear. Looks to me like I could go bigger in the rear, maybe 275 if I had at least 8" rims out back. Hope that helps.
Old Dec 6, 2010 | 11:15 AM
yeahbuddy's Avatar
For those of you who are interested in seeing how they ended up looking. 235/60R15 on front and 275/60R15 on rear. Needed to upgrade to Hijacker air shocks on rear because I was experiencing really bad rubbing on even the slightest dips. The front shocks and springs need to changed out next and it will sit right. Nice and smooth believe it or not.
Old Dec 8, 2010 | 05:47 PM
Wyze's Avatar
Looks great!!!!!
Old Dec 8, 2010 | 06:33 PM
gearheads78's Avatar
car guy
Too late now but the tire size is not the problem. The wheels BS is too far out causing the rubbing. 8" wheel with about 4.5 BS on a 275-60 is about right
Old Dec 8, 2010 | 07:28 PM
yeahbuddy's Avatar
The back spacing was the issue. I was told they were 3.75 which would clear but that was wrong. The rear driver side tire was rubbing the edge of the fender on dips/bumps and it actually shredded the tire a little bit. Lesson learned. The shocks need to be changed out all around so it was an opportunity and reason to take care of it. Thanks for the comments.
Old Dec 8, 2010 | 09:16 PM
68vaolds's Avatar
By going to 15's,did it throw off your speedometer reading?
Old Dec 8, 2010 | 09:18 PM
yeahbuddy's Avatar
I haven't noticed a difference with the speedometer.
Old Dec 29, 2010 | 06:22 PM
raidr8's Avatar
19 sixty hate
do 20 inch rims fit a 1968 cutlass with no modifications
Old Dec 29, 2010 | 07:39 PM
car guy
please don't ask the same question in multiple threads
Welcome to the site
Old Dec 30, 2010 | 06:46 AM
MHENDERSON's Avatar
What a nice car .2 door 4 doors they are all oldsmobiles just the same!!
steverw
Wheels and Tires
Jan 9, 2013 06:19 AM
Brians64f85
Oct 23, 2012 04:19 PM
doc
Sep 23, 2012 09:42 AM
Wraythe
Feb 20, 2012 10:06 AM
1968Cutlassfallbrook
Wheels and Tires
Oct 9, 2011 09:47 AM
