? About 255 45 18 on 72 cutlass supreme
Those tires are virtually identical in width and overall diameter to 255/60-15s. I've run the latter on several A-body cars. The rear is no issue. Expect the fronts to rub slightly if you hit a bump with the front wheels turned all the way to one side (for example, if you hit a bump while turning into a driveway). This assumes you have wheels with proper width and offset. I used 15x7 SSII wheels with zero offset. Any non-zero offset will likely increase rubbing. Any additional wheel width may also be a problem, though the shorter sidewalls will mitigate that.
Impure Cutlass
Wheels and Tires
December 30th, 2017 07:31 AM
yankees
Wheels and Tires
September 10th, 2012 06:53 AM
