Click Here
? About 255 45 18 on 72 cutlass supreme
Old Nov 2, 2018 | 06:07 AM
Scottsand1983's Avatar
Has anyone used a 255 45 18 on all four tires will there be any fitment issues
Old Nov 2, 2018 | 08:16 AM
Those tires are virtually identical in width and overall diameter to 255/60-15s. I've run the latter on several A-body cars. The rear is no issue. Expect the fronts to rub slightly if you hit a bump with the front wheels turned all the way to one side (for example, if you hit a bump while turning into a driveway). This assumes you have wheels with proper width and offset. I used 15x7 SSII wheels with zero offset. Any non-zero offset will likely increase rubbing. Any additional wheel width may also be a problem, though the shorter sidewalls will mitigate that.
Impure Cutlass
Wheels and Tires
Dec 30, 2017 07:31 AM
mbolds
Feb 8, 2015 12:10 PM
yankees
Wheels and Tires
Sep 10, 2012 06:53 AM
car_designer
Wheels and Tires
Apr 2, 2011 04:51 PM
