Click Here
215 vs 225
Old Jan 29, 2013 | 08:39 AM
LI Olds's Avatar
215 vs 225
my car currently has 215/75/14 with original hubcaps. my plan was to switch to SSII and 225/70/14
below is a cut and paste from a tire calculator.. it doesn't seem like much of a noticeable difference.. Is it worth switching?
Side by side Overlay
Current Tire New Tire Difference Diameter inches (mm) 26.7 (678.1) 26.4 (670.6) -0.3 (-7.5) -1.1% Width inches (mm) 8.46 (215) 8.86 (225) 0.39 (10) 4.7% Circum. inches (mm) 83.87 (2130.31) 82.94 (2106.75) -0.93 (-23.56) -1.1% Sidewall Height inches (mm) 6.35 (161.25) 6.2 (157.5) -0.15 (-3.75) -2.3% Revolutions per mile (km) 755.45 (469.41) 763.9 (474.66) 8.45 (5.25) 1.1% Forum embed code (copy & paste in your post):
Speedometer Difference Speedo Reading Actual Speed 20 mph (32.19 km/h)19.78 mph (31.83 km/h)25 mph (40.23 km/h)24.72 mph (39.79 km/h)30 mph (48.28 km/h)29.67 mph (47.75 km/h)35 mph (56.33 km/h)34.61 mph (55.7 km/h)40 mph (64.37 km/h)39.56 mph (63.66 km/h)45 mph (72.42 km/h)44.5 mph (71.62 km/h)50 mph (80.47 km/h)49.45 mph (79.58 km/h)55 mph (88.51 km/h)54.39 mph (87.54 km/h)60 mph (96.56 km/h)59.34 mph (95.49 km/h)65 mph (104.61 km/h)64.28 mph (103.45 km/h)
Old Jan 29, 2013 | 09:45 AM
I'd look for 15" wheels, your limited in tire sizes for the 14's. If you like the look of the diameter of the tire's you have on there now, the 3/10th's of an in gain will not effect anything, if thats your question.
Old Jan 29, 2013 | 09:47 AM
1970cs's Avatar
Lansing built
Very nice on the homework/mathwork. I guess my only question is, how old are your 215/75/14? Bare in mind that most manufacturers suggest 8-10 years on tires. Also 14" rubber is getting tougher to get, as far RWL tires in that size P225/70/14 your down to three choices!
Pat
Old Jan 29, 2013 | 10:24 AM
LI Olds's Avatar
Pat
the tires are fine, looks like at least 60% tread left,
as far as tires If I go 225/70/14 I am going to go with BFG radial T/A
Old Jan 29, 2013 | 10:39 AM
oldsmobiledave's Avatar
Old vs worn.
The fact that there is 60% tread left is irrelevant. You were asked now OLD are the tires. Read the date code on the tire. If it is 8 years old or more toss it out & repalce.
14" tires are a waste of good rubber. Buy some 15" rims & enjoy the looks & handling that only a 15" tire will afford.
Old Jan 29, 2013 | 11:13 AM
1970cs's Avatar
Lansing built
Not that you may have seen the tire/wheel combo before but here it is, exact per your specs.
Old Oct 8, 2013 | 02:09 PM
Maverick22's Avatar
So you are running 225-70-14's
Old Oct 8, 2013 | 02:24 PM
1970cs's Avatar
Lansing built
Yes sir! I used to have Uniroyal tiger paws RWL the same size but they are NLA. Major branded left are BFG T/A, Cooper Cobras and Firestone Firehawks indy 500
Dollar wise BFG's are in the middle, quiet ride good side profile but not so great looking tread pattern.
Pat
Old Oct 8, 2013 | 03:32 PM
RetroRanger's Avatar
72 Olds CS
X2
find a nice set of 15"SS3s i roll 255-60-15s on SS3s very happy w the ride handling and look.
Old Oct 8, 2013 | 03:41 PM
Maverick22's Avatar
X2
Sorry to Highjack a post.
I have a super clean set of 14" stock wheels, original to the car. I was hoping to keep these wheels on and then maybe get some aftermarkets, cragers with tires a little larger and wider once i get the car fixed up. I currently have the 14" stock and 15" keystone wheels for the car with rotten tires (haven't been driven for 20+years).
I am trying to decide between 225-70-14 all around or 245-60-14 rear/235-60-14 front.
I like the size of the 70, but the width looks better for the 60.
507OLDS
Nov 12, 2012 06:36 AM
Alex72cutty
Wheels and Tires
Jul 27, 2012 09:22 AM
Alex72cutty
Jul 27, 2012 01:39 AM
pcard
Feb 29, 2012 12:00 PM
1965zoso
Feb 16, 2011 05:25 PM
