Vista Beast tuned up
Old May 7, 2012 | 05:53 PM
WoofWagon's Avatar
After two new carbs (first carb was puking fuel and had to be returned), points, plugs, wires, master cylinder, wheel cylinders, shoes, shocks and brakes:
Here's a short vid of the Vista Beast running as it should. I can now lay a 50' strip of rubber no problem now.
http://www.youtube.com/watch?v=nE_QxAsqA6g
Manifold vacuum is a bit low, but I'm attributing that to the cam as the engine isn't burning oil or suffering from low compression. Next on the list mechanically is a high torque mini starter, I think the original starter is on it's way out.
young olds
Jun 15, 2016 06:28 PM
Odmark
Aug 7, 2013 07:51 AM
KeithA0000
Apr 1, 2009 04:23 PM
branchman88
Oct 12, 2008 07:35 PM
dagr8tim
Jun 2, 2008 12:14 PM
