Vista exhaust
Old Feb 14, 2021 | 04:31 AM
oldsrock's Avatar
Vista exhaust
Hey everyone,
I have a 68 Vista with 350 cid engine. Has anyone found a source for a bolt on dual exhaust system for these cars? I’d prefer the pipes exit behind the rear tires, not at the bumper.
Old Feb 14, 2021 | 05:46 AM
VC455's Avatar
Barely Registered
That's an essential, not a preference. If you do at-the-bumper, you will get a bit of exhaust smell coming in around the tailgate window. And with the window down you'll have virtually direct exhaust into the car. If you have an air deflector, it will only help a bit.
I'm not sure about a pipe supplier. Did you ask Waldron?
Hearthrob made my exhaust but it was a bit expensive and doesn't fit well.
Old Feb 14, 2021 | 05:53 AM
70vista's Avatar
On my 70 vista cruiser I used a flowmaster kit for elcamino and it worked great. I used head pipes from pypes exhaust. Steve
Old Feb 14, 2021 | 06:18 AM
The only difference between a Vista and a Cutlass as far as exhaust fitment is wheelbase. I've simply welded in a section of straight pipe to extend the Cutlass pipes the extra 9" (121" wheelbase vs 112"). I use ElCamino tail pipes to exit out the sides behind the rear wheels so that I don't suck exhaust in when driving with the back window open.
Old Feb 14, 2021 | 05:43 PM
oldsrock's Avatar
Thanks for the suggestions, never thought of El Camino tailpipes. Sounds like I can put something together pretty easy.
Old Feb 14, 2021 | 06:56 PM
FYI, dual exhaust was a factory option on Vistas with big blocks, but those pipes are long out of production.
NP 70 442
Jun 24, 2020 02:19 PM
NJRob
Aug 16, 2019 07:44 AM
F-85 4-4-2
May 14, 2018 05:38 AM
68442
Vista Cruiser & Wagons
Jul 24, 2016 06:05 AM
70vista
Sep 29, 2009 08:40 AM
