Turbo 350 in Vista Cruiser??
Old Oct 11, 2017 | 04:55 AM
When I bought my 1970 Vista Cruiser I was told it had a Turbo 400 behind the 350 4bbl. I had to rebuild the transmission and found that it has a Turbo 350 long tailshaft. Since I have seen many Vistas with the turbo 400 behind a 350 including the 72 in the cars for sale section now. I checked the numbers of the trans and it does match the vin so I'm sure it's the original. Any thoughts or comments on this? Thanks Greg.
Old Oct 11, 2017 | 06:48 AM
Those transmissions are neither a TH400 nor a TH350. 1967-69 Vistas with small block motors used a TH375. This is a light duty version of the TH400 with lower strength internals and the smaller TH350/Jetaway output shaft.
The 1970-up Vistas with small blocks used the TH375B, which is an upgraded TH350 with HD internals.
The TH375 and TH375B were also used in the Delta 88 cars with small block motors.
Old Oct 11, 2017 | 10:43 AM
Ok, Thanks Joe. I do remember the 375's now you mention it.
matviar
Feb 26, 2012 11:05 AM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
