New Wagon Decode Vin
Old Oct 18, 2017 | 12:20 PM
g_field07edd's Avatar
I bought a 69 Cutlass Wagon over the weekend and was told it was about 95% original outside of maintenance items and paint. Can anyone help me decode the VIN and Cowl tag as well as tell me where to look on the engine block, heads and trans to check that it is all original?
Im not too concerned if it is all original or not but figured it would be a cool thing to check out.
Also are there any other things I should look for? IE rear end codes, or build sheets
VIN: 336359M435427
Cowl: ST 69 33636LAN432543 BDY
TR 912 57 57 PNT
7A
Thanks for the help
Also I know you guys like pictures so I attached the pictures I have of it so far.
Old Oct 18, 2017 | 12:49 PM
VC455's Avatar
Barely Registered
Trim tag shows 1969 Olds Cutlass Station Wagon. Glade Green over Glade Green. Green Vinyl interior, built in Lansing in the first week of July.
There may be other things hidden there, but you will hear about it.
Old Oct 18, 2017 | 01:27 PM
jaunty75's Avatar
VC455 covered the cowl tag. There isn't any other information on it.
As far as the VIN, it tells you little that you can't tell by looking at the car.
3 = Oldsmobile division
36 = Cutlass V-8
35 = 2-seat station wagon body style
9 = model year 1969
M = assembly plant (Lansing)
435427 = sequential serial number at the Lansing plant
As far as checking the numbers-matchingness of the car, there would a derivative of the VIN stamped on the engine block and on the transmission that would include the last six digits of the VIN. If these numbers match, those would be the original engine and transmission.
Old Oct 20, 2017 | 03:59 PM
Well I climbed under the hood today and took some pictures. It is the original engine block. It also has #5 heads on it. Does anyone know if these were factory option for this car or were they swapped at some point?
on a side note with everything in the car it is hard to get pictures of the head casting letter.
You can kind of see the #5 on the head here. This is the passenger side. Completely impossible for get a pic of driver side with alternator bracket in.
Old Oct 20, 2017 | 05:52 PM
No. 5 heads were used on every single 350 motor that Olds built in 1968 and 69.
tex70
May 16, 2012 06:41 AM
442b
Apr 22, 2012 06:32 PM
MDC
Dec 5, 2008 10:33 PM
greghsc
Aug 18, 2008 12:24 PM
don1903
Nov 7, 2006 09:13 PM
