Decode vin on motor
Old Apr 9, 2012 | 08:53 PM
442b's Avatar
Decode vin on motor
Ok, so I found a used motor which I'm told is a good running 455. Here's the engine number stamped on the front left tab in front of the exhaust manifold. I need someone to decipher for me. 34M725139. Also if you could provide a link to a site so I can do this for myself in the future would be great. Thanks for any help.
Old Apr 9, 2012 | 10:38 PM
rcorrigan5's Avatar
Randy C.
That's what they call the VIN derivative. It's a shortened version of the vehicle identification number on the dash. Here's what it means:
3 = GM division = Oldsmobile
4 = model year = 1974
M = assembly plant = Lansing MI
725139 = assembly plant sequential number
There is a technical data base at this site that you can access and look up all kinds of info. There is another technical data base at www.442.com that can also be beneficial.
Randy C.
Old Apr 21, 2012 | 01:32 PM
442b's Avatar
Thanks for your reply. I'm actually trying to figure out if this is a 455 motor & not a 350. Is there a way to tell the difference between the two? Thanks
Old Apr 21, 2012 | 01:44 PM
GAOldsman's Avatar
"Car"mudgeon
The front of engine above the water pump should read 396021 on most 455 blocks from 68-76
Old Apr 21, 2012 | 02:12 PM
Simple.
The 455 is wider than the 350.
Almost all parts from one can be bolted on to the other (whether they'll work well is a different question), EXCEPT for the intake manifold, so just look at the intake manifold, and you'll know right away.
Here are two pictures:
Old Apr 21, 2012 | 02:29 PM
midrange's Avatar
Shaking out the cobwebs..
Edited: Nevermind, I checked the link above, and answered my questions.
Old Apr 21, 2012 | 03:00 PM
2blu442's Avatar
Just to throw a little more information out here it looks like the 350 is about 13ish inches across the intake and the 455 about 15ish inches. John
Old Apr 21, 2012 | 08:12 PM
442b's Avatar
Ok, so the motor I have has an Edelbrock Performer 455 Oldsmobile Intake on it & that intake won't fit on a 350 so I can be sure it's a 455 motor.? Thanks for clarification.
Old Apr 21, 2012 | 08:15 PM
2blu442's Avatar
They also made small block performer mainfolds, but if yours says 455 then yes it must be a big block. It still could be a 400, 425 or 455 The way to know for sure is check the number with the large letter behind it between the water pump and intake manifold. I can come up with a picture of the location if that would help. John
Old Apr 22, 2012 | 08:47 AM
442b's Avatar
Hi John
Yes, let me know what the letter should be behind the water pump. A picture of what I'm looking for would be very helpful. Thanks for the help.
Old Apr 22, 2012 | 09:39 AM
2blu442's Avatar
Here's a link to a thread with several pictures. I just realized there's no 455 in this old thread, but there is an example of a 425 with a letter D after the number and a 350 with a large 2 after the long number. That's where you need to look and if it is a 455 there will be a large F at the end of the numbers. Depending on what year there may also be a small capital A to the lower right corner of the letter F. Let us know if you need anything else. John
https://classicoldsmobile.com/forums...s-engines.html
Old Apr 22, 2012 | 06:32 PM
Octania's Avatar
A light scraping with a screwdriver usually reveals the casting number of the block. If it's convenient, you might stuff the business end of the car wash wand down there and blast it clean. You really only need the large main ID letter or number (or combo for 1977+ motors], but the final 3 digits of the 6-digit casting number can't hurt. MOST with few exceptions have the large main ID right next to the oil pressure sender, on the engine's LH side. Far and away the most common are the 68-76 "2" 350 block, and the F or Fa 455 blocks. After the weight reductions for 1977, You will find 2B 260, 3B 350, 4B or 4A sometimes 403, and various 307's that often don't have this (######-Main ID) format; typically they will say "5.0L" or similar in that area among the other chracters.
common 350 #2 ID:
Actually, note the "SP" mark cast in there- this is a siamesed bore 350 which MIGHT be the root of the "Solid Main Web 403" rumors.
A hella-rare 403 casting ID:
Another not so common 403 casting, allegedly a SMW unit:
A less-uncommon "4A" 403 casting- like in my 85 442 at this time
tex70
May 16, 2012 06:41 AM
egknz
Mar 7, 2009 10:33 PM
MDC
Dec 5, 2008 10:33 PM
greghsc
Aug 18, 2008 12:24 PM
don1903
Nov 7, 2006 09:13 PM
