68 vista cruiser windshield question
So, my windshield on the 68 vista is trashed. Having a hard time locating a source that actually has them.
Question - Are all 68-70 GM A-body windshields the same?
Will a cutlass 2dr windshield fit in the vista cruiser?
thanks
thanks
2dr hardtop, 2dr convert, and 4dr/wagon are all different. Also be aware that the 1970-72 have the antenna in the glass.
Did you try Google? Here's one source for $185 (the windshield is near the bottom).
As Joe said, the Vista Cruiser windshield is the same as a 4-door A-body windshield. These are available, most commonly, with a Chevelle designation. They can be date coded.
The in-glass antenna connector may be a bit different but you can work with it.
Your local glass person can get the glass and install it for cheaper than you can buy it yourself mine cost me less than 250 bucks labor glass urethane and foam kit installed. It's A 4 door sedan glass, I used a 70 glass and installed the windshield antenna in my 68.. I used a windshield antenna from a 72 to 72 Monte Carlo. Works great
47 Convertible
July 1st, 2017 11:24 AM
stlbluesbrother
Vista Cruiser & Wagons
August 12th, 2016 02:13 PM
dedsleds
December 11th, 2010 05:56 AM
