carb linkage
Old Nov 13, 2020 | 08:10 AM
tkelburn's Avatar
carb linkage
Hi Guys, I just switched my 1955 olds 324 from the original rochester 2bbl carb to the original roghester 4bbl. Now I can't get the 4bbl. to get to wide open throttle. Did they use different linkage rods?
Thanks in advance for any help on this. Tom
Old Nov 15, 2020 | 11:08 PM
Pat55Olds's Avatar
I'll try to get you some pictures tomorrow.
Old Nov 16, 2020 | 06:06 AM
tkelburn's Avatar
Thank You Pat, much appreciated! Tom
Old Nov 16, 2020 | 06:46 AM
Ozzie's Avatar
Yes.
Old Nov 16, 2020 | 08:19 AM
tkelburn's Avatar
Thanks Ozzie, Do you know the difference in the lengths?
Old Nov 16, 2020 | 11:32 AM
Pat55Olds's Avatar
Ok, not the greatest picture, but hopefully it will help you.
From A to B I have about 5.1/2"
let me know if you need more
Old Nov 16, 2020 | 12:44 PM
tkelburn's Avatar
Thanks Pat, I will check it out tomorrow
Old Nov 16, 2020 | 05:20 PM
Ozzie's Avatar
Pat's number is likely correct for the 4 BBL. The rod is adjustable. You already have the 2 BBL. version. Mine is lost in the parts storage.
Old Nov 17, 2020 | 02:35 PM
tkelburn's Avatar
Thanks Ozzie, mine is set at about 5.75". I will have to play with the adjustments. Right now it is shifting to soon in all gears and will not downshift to passing gear with heavy acceleration. Tom
Old Nov 17, 2020 | 03:28 PM
Ozzie's Avatar
If you have the 1955 Oldsmobile shop manual look on pages 3-96 and 3-97. The adjustments for the Hydramatic are shown there. But you will likely need the 4 BBL. linkage for them to work properly.
Wyocutlass71
Sep 6, 2019 07:32 AM
aqua67w30
Oct 29, 2018 02:11 PM
CutlassLegend
Sep 14, 2011 11:34 AM
66ninetyeightls
May 18, 2010 02:59 PM
66ninetyeightls
Mar 28, 2010 07:40 AM
