carb linkage
carb linkage
Hi Guys, I just switched my 1955 olds 324 from the original rochester 2bbl carb to the original roghester 4bbl. Now I can't get the 4bbl. to get to wide open throttle. Did they use different linkage rods?
Thanks in advance for any help on this. Tom
I'll try to get you some pictures tomorrow.
Thanks Ozzie, mine is set at about 5.75". I will have to play with the adjustments. Right now it is shifting to soon in all gears and will not downshift to passing gear with heavy acceleration. Tom
If you have the 1955 Oldsmobile shop manual look on pages 3-96 and 3-97. The adjustments for the Hydramatic are shown there. But you will likely need the 4 BBL. linkage for them to work properly.
CutlassLegend
Sep 14, 2011 11:34 AM
