Vacuum wiper system plumbing drawing
Old Nov 27, 2019 | 04:31 AM
Sporty45's Avatar
Does anyone have a drawing that shows the plumbing for the vacuum wiper system in a 47 coupe? None of my books show it. I appreciate any help.
TIA
Old Dec 10, 2019 | 08:18 AM
Russ Golesh's Avatar
I don't have a diagram, but most old vacuum wiper motors have a single rubber vacuum hose from the vacuum side of fuel pump to a nipple on vacuum wiper motor. These old motors mostly used leather membranes which dry out after many years and slow down or stop working.
The motor is usually mounted under dash with 2 machine screws or cap screws. Climb under your dash with a bright light and look for the motor. If the vacuum hose is dried out or cracked, old & brittle, replace it with fresh hose. If the motor is very slow, a trick we old timers use is to use a small plastic syringe and squirt about 1 or 2 capfuls (about a tablespoon worth) of
DOT 3 brake fluid into the vacuum port. Gently work the wiper arm lever back & forth by hand. Then, start the car and work engine at idle, plug the vacuum hose into the motor & turn the switch on. It should work fine if it's still any good. If not, it can be rebuilt with new seals, etc.
Best of luck,
Russ
Old Dec 10, 2019 | 10:49 AM
Sporty45's Avatar
Thanks for the info Russ, but my car isn't put back together yet. In fact, there isn't even a dash in it yet to look under! If you look at my post you will see at the bottom it says "my build", if you click on it you will see where I am at this point. Right now I am just gathering some future needed info as it has gotten too cold here to do much work in the garage. I may end up going to an electric wiper motor, but wanted to try the stock vacuum set up first.
Old Dec 10, 2019 | 04:30 PM
I guess I'm reading only your posted verbiage about the wipers. No "see my build" is at bottom (or anywhere else) on your post
Old Dec 10, 2019 | 04:54 PM
Sporty45's Avatar
Under my signature that says "47 Model 66 Coupe(under construction!)" it says "My build" Doesn't that appear at the bottom of my post? I can see it when I post, so not sure why it isn't showing up when you view my posts
Old Dec 10, 2019 | 06:43 PM
Sporty45,
Send me a PM with your first name & email address and I'll email you a screen shot of what I'm seeing on my end.
Russ
Old Dec 11, 2019 | 07:28 AM
I can see the signature. Check your firewall settings Russ.
377rick
Jun 6, 2019 07:07 AM
Octania
Mar 13, 2013 09:36 AM
The Tin Man
Aug 16, 2012 12:06 AM
Erinyes
Jun 13, 2010 07:05 AM
Fletch
Dec 16, 2009 04:30 PM
