Vaccum Line diagram
Old Mar 2, 2019 | 01:54 AM
Oldskillen's Avatar
Question Vaccum Line diagram
Hey
​​​I am completing my olds 57 before the season, however i have not managed to get the vaccum system complete. Can anyone help me with the vaccum chart showing the whole vaccum system and not just the heating system as in the shop manual
/Oldskillen
Old Mar 2, 2019 | 05:06 AM
It is neither necessary nor in your best interest to post the same question in multiple places on the forum. You'll get a better response more quickly if you keep all replies in a single thread so incorrect info can be caught and corrected. Good luck.
Old Mar 15, 2019 | 07:04 AM
ivmachine's Avatar
I stumbled through this last year. Are you looking how to connect up the vacuum lines in the dash or all the other stuff (Fuel/Vacuum pump to carb, wipers, washer pump, etc)?
4GC or J2 (3 carbs)? If J2 are you using mechanical linkages to open the outside carbs or relying on diaphragm?
Old Mar 15, 2019 | 08:01 AM
Oldskillen's Avatar
Hello
​I am looking how to connect up the vacuum lines to, fuel/Vacuum pump to carb, wipers, washer pump, heater etc
The carburator is a J2 using linkages
Old Mar 15, 2019 | 08:05 AM
To the OP, you might want to post some pics of your setup so we can give you some direction on what to hookup where. You should definitely look in to getting a Factory Service Manual and Chassis Manual. They have all the info you need. Hopefully, someone comes along withe the schematic your looking for. Otherwise KISS... start with manifold vacuum to your distributor.
Leadfoot
Jun 13, 2024 06:24 AM
truckman5000
Jun 25, 2016 03:43 PM
mmurphy77
May 17, 2013 06:53 AM
pogo69
Intrigue
Jul 12, 2012 06:22 PM
mitsudave
Mar 8, 2007 03:33 AM
