Suggestions for '46 98 Coupe Trunk Support Rod
Old Nov 16, 2018 | 05:34 AM
'46-98's Avatar
My car is missing the lift support rod on the trunk lid. Very unlikely, but does anyone have a spare for an '46 98 Custom Coupe?
Any idea if a modern gas strut would handle the weight of the trunk lid?
I was thinking I will probably have to make a locking dog leg arm.
Old Nov 16, 2018 | 05:40 PM
rocketraider's Avatar
Oldsdruid
A pair of struts might. Check some streetrod and Chevy forums and parts suppliers since most GM from that timeframe used that lock rod.
Old Nov 16, 2018 | 08:01 PM
Nailheadcanuck's Avatar
Oh no, not again...
From: Sherwood Park, Alberta, in the Great White North
That rod is exactly the same in a Buick from 1942 to 1948.
Another option if you want something more modern is a gas filled cylinder off of a modern hatchback or SUV.
Old Nov 16, 2018 | 08:31 PM
FuturamicOldsmobile's Avatar
Hydraulic ram like gene Winfield
Old Nov 16, 2018 | 09:20 PM
If you know the weight of the lid contact one of the strut manufacturers and they can make a suggestion on what to supply you with.
Old Nov 17, 2018 | 05:32 AM
'46-98's Avatar
Thanks for all the suggestions. I like the original lock rod style, I have the same kind on my '38 Dodge and they work great. I will continue searching for a possible GM match.
Old Nov 17, 2018 | 06:07 PM
Sporty45's Avatar
Would something like this work?
https://www.ebay.com/itm/1946-47-48-...4383.l4275.c10
Old Nov 17, 2018 | 06:12 PM
Sporty45's Avatar
Or this,
https://www.ebay.com/itm/ORIGINAL-TR...el!03825!US!-1
Old Nov 18, 2018 | 04:46 AM
'46-98's Avatar
Dennis, thank you very much for your research. You did much better than me on Ebay, both supports look promising. The NOS unit looks extremely close to the correct dimensions, but possibly a little long.
The one for the Buick, hopefully a Sedanette, looks like this model has the exact truck lid as my 98. I will contact seller for open and closed lengths.
Does anyone have the cross reference for the Chev 4114965 part number listed as a support?
Old Nov 18, 2018 | 06:26 AM
Sporty45's Avatar
No problem, I enjoy the research! Good luck.
Old Nov 25, 2018 | 04:56 PM
47 Convertible's Avatar
Olds Trunk Rod style and length
Nick, trunk support rod on my 68 series convertible is 28 inches open and 16.5 closed. A couple of photos attached.
Old Nov 26, 2018 | 05:42 AM
'46-98's Avatar
Jerry,
Thank you for the measurements and photos. I have heard back from both sellers on Ebay and yours and the 2 others are basically the same open and closed lengths. As you suggested it would probably best to go with the C body Buick one.
Thanks again for your assistance.
Old Dec 1, 2018 | 10:11 AM
'46-98's Avatar
Thanks again for the help
Ended up buying the 46' Buick one that Dennis found on E-Bay. Cleaner her up, painted it and installed. Has to be the same unit as the original, as it works perfectly
Old Dec 1, 2018 | 10:18 AM
Sporty45's Avatar
Happy I could help, and glad it worked!
Old Dec 1, 2018 | 06:42 PM
re. book you are looking to buy
Dennis, somehow lost your PM on the manual you need. I did look at mine and it is different and not as specific. Buy the one you had put a link to.in the PM
Jerry
Old Dec 2, 2018 | 04:08 AM
Sporty45's Avatar
Jerry
Done!
TheBigBlueBoat
Body work
Mar 26, 2019 06:59 AM
Joah_from_Alberta
Oct 4, 2016 02:19 PM
cfair
Apr 4, 2014 07:27 AM
L69
Oct 14, 2013 03:50 AM
Allan R
Nov 20, 2009 08:54 PM
