Power steering pump rebuild.
Old May 24, 2010 | 07:18 AM
Fletch's Avatar
I had seen an ad for a company that would rebuild Power Steering Pumps.
Saw the Ad in Olds Magazine. Now I cannot find Ad.... anybody have a good turnkey rebuilder ??
More concerned about bearings and general fitness . Most of these rebuilders install seals and then paint the unit.
Suggestions...
Regards,
Fletch
Old May 24, 2010 | 07:20 PM
2blu442's Avatar
Fletch, I've not used this vendor but several guys on this site have and I've only heard good things about Chip's work.
http://www.powersteering.com/products.htm
John
Old May 24, 2010 | 07:29 PM
bigoldscruiser's Avatar
2 '66 98's
I had my steering box rebuilt and the ratio changed and the pump rebuilt by Chip. The work is totally satisfactory and the turnaround time was not too bad. (I forget exactly how long now-it was a couple of years ago) The work was not cheap but I had no other estimates to compare with!
Old May 24, 2010 | 09:23 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Chip is very reputable and an Olds guy. I have never heard anything bad about him. He did a great job for me.
Old May 25, 2010 | 03:08 AM
oldsonharmont's Avatar
If it's the pump that you want rebuilt, try an exchange unit from NAPA for about $40. (you keep your own reservoir) I started with just a seal kit, but went the exchange route to get the warranty. Don't forget to flush the system with new fluid when you get it back together.
Old May 25, 2010 | 06:50 AM
Fletch's Avatar
Thanks to ALL for the follow up. "powersteering.com" was the company who ran the Ad.
Called chip.... I will send him the pump. Napa no longer handles the vintage pumps.
Thanks again,
Fletch
Old May 25, 2010 | 12:09 PM
That's interesting, I replaced the pump in my '71 just a few months ago.
Were you looking for an older application?
Old May 25, 2010 | 12:53 PM
Fletch's Avatar
Yes.. much older, 1957
Old Jul 12, 2010 | 10:14 PM
johnbost's Avatar
57 Olds power steering fluid
I am just re-installing my 57 Olds power steering unit. Does anyone know what is the best fluid to purchase and install, since the shop maual states " Hydraulic fluid" , which is the same spec. for the trans.
Old Jul 13, 2010 | 08:19 AM
Fletch's Avatar
I have used Hydromatic fluid, with "Red Line" additive.
Hope this helps.
Fletch
Old Jul 13, 2010 | 08:57 AM
johnbost's Avatar
57 olds power steering fluid
Fletch: Thanks for your response. I have looked at automotive "chain store" and could not find just regular hyromatic fluid. Could you tell me where I may find this fluid, along with the " red-line" additive? Also since you have a 57-Olds, Do you know of anyone that may have two spinner style hupcaps in VG condition? two VG condition fender rockets ? Also looking for a wonder-bar radio in working condition.
Thanks, John
Old Jul 13, 2010 | 01:03 PM
Fletch's Avatar
I Have not looked at the trans can lately, but I think it is also classified as Type A trans fluid. Red line is sold at hot rod stores etc. I use a small amount in the power steering.
Spinner caps require clips. I would use Fusick.. expensive but correct and good quality.. I believe You must have 14 "wheels .
I had my radio rebuilt in Oregon.... Radio Doctor... very good work.. no Wonder Bar, I remember when they were new..... did not work so well.. Old radios do not have the range, newer radios have., thus old wonder Bar's seemed to search alot.
Now that I have said that... 10,000 Wonder Bar owners will correct me !
Fletch
Old Oct 3, 2010 | 01:37 PM
oldzy's Avatar
Busy guy
chip_woyner_if@pop.hypermart.net
(ultimately generated from captainchip@powersteering.com)
mailbox is full: retry timeout exceeded
rroth01
Mar 5, 2014 07:57 PM
nicks1966
Jan 12, 2014 01:46 PM
adis
Feb 10, 2012 01:22 PM
442oldslawyer
Apr 29, 2010 09:22 PM
oldsonharmont
Jan 8, 2010 09:38 PM
