Need a master cylinder distributor block for a 53 Super 88
Old July 20th, 2018, 06:22 PM
Oh no, not again...
Nailheadcanuck's Avatar
Location: Sherwood Park, Alberta, in the Great White North
I'm new here and not very well versed in Olds parts yet. I'm looking for the distributor block off the master cylinder for a 1953 Olds Super 88 with manual brakes. We've searched high and low for one of these and just can't make it happen. I need one of these so I can move the car.
Anyone got one of these things?
Nailheadcanuck is offline
Old July 20th, 2018, 09:04 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Give Karp's Power Brake Service a call. They rebuilt my treadlevac and are good folks. I think the guys name is Jeff but I could be wrong. He may have a bin of spare parts. Here is a link.
http://www.karpspb.com/booster.htm
redoldsman is online now
Old July 21st, 2018, 12:08 PM
D. Yaros's Avatar
Am able to find one for a Chevrolet. Might it work?
https://www.summitracing.com/parts/s.../model/bel-air
D. Yaros is offline
Old July 21st, 2018, 01:34 PM
Oh no, not again...
Those are both good leads, I'll follow up, thanks!
Old July 22nd, 2018, 09:30 AM
D. Yaros's Avatar
Do let us know what you end up using and from where it was obtained? Doing so will be of help to others.
D. Yaros is offline
Old July 22nd, 2018, 09:59 AM
okie88's Avatar
I think what you're referring to is actually a fitting off the master cylinder, not a distributor block as used on later models. If so the same fitting was used 49-56 although the 49-50 used a sending unit for brake lights that 51 and up didn't use. I doubt very much they are reproduced. you probably need to look for used. I have some old master cylinders that I could pull one from if you don't have any luck elsewhere.
okie88 is offline
Old July 22nd, 2018, 10:06 AM
redoldsman's Avatar
It has been a while since I had the master cylinder off my 54 but I think the fitting that goes on the end of the master cylinder has a bolt (maybe special) that goes through it and then the lines come out of each side. If that is the case I don't think the one for the 53 Chevy will work. I just went out and looked at my shop manual and it doesn't give a good picture of it. It does show a cutaway version and it does have a bolt that goes through it with seals. I would take Okie88 up on his offer.
Old July 22nd, 2018, 10:54 AM
Oh no, not again...
Yes, that's it, and yes, we haven't been able to find any used ones around here, there are no vintage Olds laying around in the salvage lots anymore. If you find one, cost and shipping to Edmonton, Allberta Canada, T8H 0J9 please!
I seem to recall that Redoldsman is right; it bolted to the frame somehow. I haven't looked at one for a long time and haven't found my service manual yet.
Old July 22nd, 2018, 11:09 AM
redoldsman's Avatar
It doesn't bolt to the frame. It bolts right into the end of the master cylinder and then the brake lines go in each side of it. You will need the bolt and seals (copper I believe) that go with it.
Old July 22nd, 2018, 11:48 AM
Oh no, not again...
Thanks for the clarification, yes, that's the stuff I need, all of it with the bolt and gaskets. The Chevy one won't work without modifying the brake lines, and I'm not in a position to do that yet. So I need the stock piece. And to clarify, it seems it is not being repopped anywhere and it seems to be an Olds only item, Chevy, Buick and Cadillac use a slightly different set up.
Old July 22nd, 2018, 04:32 PM
okie88's Avatar
I have the part pulled for you and have sent a pm with the info.
okie88 is offline
Old July 22nd, 2018, 04:54 PM
redoldsman's Avatar
Is this a great website with great people or what. Yes it is.
Old July 22nd, 2018, 06:45 PM
Oh no, not again...
PM responded to and funds sent...
And yes, this is a great site!
Old July 25th, 2018, 03:46 AM
Ozzie's Avatar
It sounds like you have what you need, but anyway, here's what the Olds parts book says:
Group 4.661, Fitting
1949-1955 exc. 1950 & 1951-98 LHD; (exc. P.B.): part number 5453708
As you expected, this number doesn't appear in the Chevy parts book.
Ozzie is offline
Old July 25th, 2018, 06:11 PM
Oh no, not again...
I'll let you all know if it'll work, i assume it will, I can't see there being any differences between the Canadian built and the Lansing built cars.
Old July 27th, 2018, 01:15 PM
D. Yaros's Avatar
  1. In Canada they speak "metric," whereas on our side of the border the language of the day is "SAE"!
D. Yaros is offline
Old July 27th, 2018, 02:00 PM
redoldsman's Avatar
I wonder if that was the case for a Canadian built 53 Olds. I kind of doubt it.
Old July 27th, 2018, 05:09 PM
Oh no, not again...
The metric thing only became an issue after 1977, prior to that we were standard like the US. The thing that had me worried was the fact that on some Canadian built models they would have used what was accessible, namely a Chevy part. Canadian Pontiac is a rebadged Chevy even as early as 1949. It looks like the Olds stuff remained Olds, and wasn't pulled from a Chevy parts bin. There were some minor differences between Canadian and American Buicks too.
Old August 1st, 2018, 12:44 PM
Oh no, not again...
The piece got here and it looks like exactly the thing I needed, thanks to all!
jason-G
July 29th, 2018 11:27 AM
Nailheadcanuck
July 20th, 2018 06:18 PM
Kensey
Brakes/Hydraulic Systems
April 20th, 2009 06:14 AM
aastm15
July 11th, 2008 06:09 AM
<marksz71>
October 20th, 2006 07:14 PM
Quick Reply: Need a master cylinder distributor block for a 53 Super 88
