"Modern"'ish Wheels for 1927 Olds??
Old May 5, 2026 | 10:39 AM
bobfake's Avatar
Hi all,
Thanks for your prior help...found the dipstick and the new electric fuel pump is working fine - no carb leaks.
I was able to get a new tire/tube/liner on a split rim with a lot of elbow grease, pain and cussing... Are there one piece wheels that will directly replace the original wheels? I have brand new 4.75-5.00-20 tires and inner tubes, but would like to have a more "modern" wheel that is one piece, looks like an original and I don't have to use the "widow maker" to remove/install.
Thanks!!!
Bob
Old May 5, 2026 | 05:02 PM
old80cs's Avatar
I'm no help at all with your question, but wow, that's a beautiful car!
Old Yesterday | 03:34 PM
Charlie Jones's Avatar
Phantom Phixer
Was the dipstick part of the oil filler cap?
Did you use a pressure regulator, or did you find a pump with less pressure?
The disc wheels you have are a rarity. Most '27 Olds had wood spoke wheels
There is no quick and easy answer to you wheel question .
Bolt on wheels didn't come along until the thirties.
Old Today | 05:20 AM
SY2455's Avatar
70 442 W-30
Minus the 4 bolts around the outside of the rim, it kinda looks like a Cragar Super Trick Wheel. Beautiful car by the way.
Olds64
Wheels and Tires
Aug 23, 2023 09:59 AM
83Delta88
Aug 25, 2022 03:02 PM
Bobby455
Nov 19, 2020 01:20 PM
Big Injun Dave
Wheels and Tires
Mar 9, 2013 12:45 PM
Tucker442
Alero
Sep 5, 2011 02:27 PM
