just got a '55 88
Old Oct 8, 2009 | 07:56 AM
ekamm's Avatar
just got a '55 88
Just got an '55 88 for$500 All there except for the carb 4bbl manifold. Found another roch 4bbl at salvage yard ,No # tag not sure if it will work or not. Looks the same basically as pics I've seen of the correct one. If not anyone where to get a core or rebuilt for it #7007000?
Old Oct 8, 2009 | 08:58 AM
ekamm's Avatar
Also the PO lost the key! What are my options on getting a new key made or new cylinder or hot wire to get her going at least?
Old Oct 8, 2009 | 09:08 AM
70 cutlass s's Avatar
You can take the cylinder out and take it to a locksmith. They can make you new key shouldn't cost very much. Good luck with car. Keep us updated.
Old Oct 8, 2009 | 09:13 AM
ekamm's Avatar
What's required to get cylinder out?
Old Oct 8, 2009 | 11:47 AM
delmontcrusier's Avatar
67 heavy metal
is it in the dash like all the old cars or was it upgraded and in the colum.I ask as if it is in the dash many times there is a ring that has to be unsrewed and then unplug it and then you have the igition switch in your hand.Now colums are trickier i have a colum that I have to take to a locks smith as I got it with no key and havn't been able to get the ignition switch out.
Old Oct 8, 2009 | 12:51 PM
ekamm's Avatar
I'll check and get back.
Old Oct 8, 2009 | 01:23 PM
citcapp's Avatar
Its in the dash and not hard to get out. First thing to do is buy yourself an Oldsmobile shop manual for your car. This helps alot when you are working on it. You can find them on e-bay most of the time. Good luck
Old Oct 8, 2009 | 02:18 PM
redoldsman's Avatar
Proud Viet Nam Veteran
It does not unplug. Each of the 4-5 wires on the switch are individually connected with a terminal lug. These babies were built back in those days. Just be sure you get all the terminals back on correctly and be sure and disconnect the battery before you start removing the switch.
Old Oct 11, 2009 | 11:02 AM
hialeah56's Avatar
1956 holiday coupe
look in the fusick catalog they have all the keys with cylinders and key blanks if you choose the locksmith route
btw how about some pictures of the 55
Old Oct 12, 2009 | 01:18 PM
ekamm's Avatar
Ok here she is.It obviously needs a lot of love and $$$$
[/IMG][/IMG][/IMG]
Old Oct 13, 2009 | 08:15 PM
Tedd Thompson's Avatar
lost key
The easy way is to take the glove box door off and take it to a lock shop. They can make a key by hand without removing it from the door. This is the same key as the one in the dash . Been there done that.......Tedd
Old Oct 14, 2009 | 05:00 AM
ekamm's Avatar
sounds like a great idea!
Old Oct 14, 2009 | 05:57 AM
What is that ugly midget doing standing in your car?
Old Oct 14, 2009 | 07:18 AM
ekamm's Avatar
Came that way some sort of voodoo doll great for Halloween.
Old Oct 15, 2009 | 03:19 PM
hialeah56's Avatar
1956 holiday coupe
[/IMG][/IMG][/IMG]
just about how I got mine, great start
Tedd Thompson
Oct 7, 2014 07:59 AM
exmoparluver
Ninety-Eight
Apr 14, 2009 09:31 PM
chip_gikey
31
Jul 3, 2008 06:47 PM
Oldsguy
May 29, 2008 03:11 AM
57olds
Ninety-Eight
May 24, 2007 05:07 AM
