63 98 6 window help just got it
Old Mar 23, 2008 | 10:11 AM
exmoparluver's Avatar
Im not new to fixing up old rides,just new to the olds cars..I have a 63 98 6 window model.394 skyrocket ultra high comp.The car is 100% original and un molested.Even all the original paper work was in the glove box.Motor runs like a dream with 53,000 actual miles.Solid body with only surface rust.Goes into gear solid but no shift out of 1st gear.It will drive and pull firm in first,when you let off the gas there is no engine braking unless its in low 1,if in drive no engine braking.Reverse works great also.Im guessing its a slimjim tranny.I hope its not shot,if it is.I will rebuild it.I want this car to be what it is,A very nice vintage car.Paint code is CCA anyone know what color that is?..For the 98 luvers out here..All options on this car work perfect,pwr windows,seat and trunk release..The Vin info on this ride is: 63-3829 Body BA 135 ,,, Trim 394 Paint CCA..Any info or tranny tips very welcome..
Old Mar 24, 2008 | 07:18 PM
Thanks for the info..
Thanks..You are right..The delivery date in the coupon book and owners manual say oct of 1962 ...The hubcaps are painted and crome..One odd thing..The car does not have a side mirror and I have not seen holes to mount one..Could you get these without a side mirror in 62/63?...
Old Mar 25, 2008 | 06:06 AM
Rallye469's Avatar
Sounds like a vacuum line fell off or is cracked.
I* replaced a transmission when I* was 18...only
to find the new one did the same thing.
(stayed in first, and went limp when I* got off the gas)
It was a cracked vacuum line.
*never the smartest kid on the block
Old Mar 25, 2008 | 08:48 AM
Bluevista's Avatar
Registered
Howdy, Does that tranny have a modulator on the side the vacuum line goes to? I'm not real familiar with the slim-jim if it has that funky convertor. I had the same problem with a '68 Pontiac and it was just a bad modulator, could also be the line itself as mentioned, low tranny fluid or dirty filter, may make a difference if the vac line goes to full manifold vacuum or ported vacuum.
Just my 2 cents woof,
Allan
Old Mar 25, 2008 | 05:10 PM
thanks for the info..I knew there was no modulator on this unit..I have drivin gm`s with the modulator unhooked and thats exactly how this acts but with no shift at all..Ill play around with it as well as check to see if the valve in the valve body is moveing with movement of the tv rod..I suppose it could be stuck..But Ill check that last...
Old Mar 25, 2008 | 05:56 PM
Welcome to the website. There is alot of good info here. Ask questions and we will try to answer accurately.
BTW, does your car have the autronic eye? My 98 has one but unfortunately it doesn't work. I read in a JWO magazine that they are blinded by modern halogen bulbs.
Old Mar 25, 2008 | 09:27 PM
I dont know if it has it or not..Ill have to look and see..
Old Mar 26, 2008 | 07:27 AM
rocketraider's Avatar
Oldsdruid
Autronic Eyes/Guide-Matics couldn't deal with reflective highway signs. That's why they were discontinued in 1970, on everything but Cadillacs. Caddys located the eye in the grille so theirs weren't quite as vulnerable to sign reflection. Even though dash-mounted units' sensitivity could be adjusted, reflective signs would still send them crazy.
You may ask why the other Divisions didn't simply move the eye to the grille. It had become a slow selling option by 1966 and was generally dealer-installed after then.
Old Apr 12, 2008 | 02:48 PM
Modern Motoring's Avatar
That would explain why the one in my 64 Lincoln was always going crazy ! Oh well, the car was sold a long time ago.
Old Apr 13, 2008 | 07:03 AM
Here is a website where you can get the autronic eye rebuilt.
http://home.comcast.net/~oldsfan/MySite/oldenburg.html
Old Apr 14, 2009 | 09:31 PM
cherokee coachworks's Avatar
hey tom
you may still get an email about this when the thread is updated. This is now my car, as of march of 09. still having the same issues, have you guys got any other suggestions? I was told that the governor should be checked, and that if you can turn it on the shaft by hand that it's no good, but if you can't turn it does that make it good?
Tedd Thompson
Oct 7, 2014 07:59 AM
cherokee coachworks
Apr 14, 2009 08:58 PM
chip_gikey
31
Jul 3, 2008 06:47 PM
Oldsguy
May 29, 2008 03:11 AM
57olds
Ninety-Eight
May 24, 2007 05:07 AM
