Generator Pulley for 54 Olds Super 88
I need a pulley for the stock generator. I see several Chevy generator pulleys form the 1954 model year advertised on EBAY. The part number for the Chevy model is Part # 3703606. Does anyone know if this is the same pulley for my Olds? If not, do you know what the correct part number would be, or where I could get one. I would like to assume that this is a par used across all lines of GM cars in 1954 but am not sure.
Thanks, Dave
Thanks, Dave
dfrede, do you have a generator repair shop in your area? I'm sure they could fix you up. I don't think that pulley is anything special and other year cars should fit as long as it's off a Delco Remy generator....Tedd
From the 1955 Olds chassis parts book
Thanks, Dave
Thanks, Dave
The number 3703606 is shown in the Chevy parts book as being for the 1953-55 commercial (truck). It is a 6 volt generator, pulley together with the fan, 2-7/8" diameter, and a single 3/8" wide groove.
eddieunderground
August 1st, 2012 02:41 AM
Hal Robinson
August 8th, 2011 03:50 PM
