Generator Pulley for 54 Olds Super 88
Old Apr 15, 2014 | 02:08 PM
dfrede's Avatar
I need a pulley for the stock generator. I see several Chevy generator pulleys form the 1954 model year advertised on EBAY. The part number for the Chevy model is Part # 3703606. Does anyone know if this is the same pulley for my Olds? If not, do you know what the correct part number would be, or where I could get one. I would like to assume that this is a par used across all lines of GM cars in 1954 but am not sure.
Thanks, Dave
Old Apr 16, 2014 | 07:00 AM
Tedd Thompson's Avatar
dfrede, do you have a generator repair shop in your area? I'm sure they could fix you up. I don't think that pulley is anything special and other year cars should fit as long as it's off a Delco Remy generator....Tedd
Old May 5, 2014 | 08:04 AM
rctoyguy's Avatar
If you are still looking for this I might be able to help you out... I'll look when I get home but I'm pretty sure I've got about 3 of those generators that I won't be using.
Old May 6, 2014 | 08:49 AM
rctoyguy's Avatar
Is this what you need? If so, hit me at rctoyguy-at-gmail.com
Old May 7, 2014 | 06:42 AM
Ozzie's Avatar
Post From the 1955 Olds chassis parts book
Thanks, Dave
The Olds parts book says that the pulley & fan are one, and the part number is 1924689 for 1951(2nd type on 45 amp. generator) through 1954, and 1955 without air conditioning (all 8 cyl. cars). The group number is 2.274. While Chevrolet uses the same group number for theirs, I cannot find any listing of that part number in their parts book for any of their automobiles or trucks from 1935 to 1961.
The number 3703606 is shown in the Chevy parts book as being for the 1953-55 commercial (truck). It is a 6 volt generator, pulley together with the fan, 2-7/8" diameter, and a single 3/8" wide groove.
eddieunderground
Aug 1, 2012 02:41 AM
Hal Robinson
Jan 28, 2012 01:32 PM
WHIPOLDS
Oct 27, 2011 05:30 AM
Hal Robinson
Aug 8, 2011 03:50 PM
Tedd Thompson
May 11, 2011 10:38 AM
