Fuel fitting at carburetor
Old Mar 6, 2024 | 04:38 AM
ub2693v's Avatar
I recently purchased an AC fuel filter with the glass bowl which gets installed at the carburetor, i have a 4GC carb, what kind of fitting is needed to get from the filter to the carburetor, the filter housing is 1/8" NPT on the inlet and outlet and i can't find a 5/16 inverted flare to 1/8"NPT anywhere, is it a Rochester/AC part?
Old Mar 6, 2024 | 05:21 AM
chopolds's Avatar
Amazon.com: Legines Brass Inverted Flare Fitting,Brake Line Adapter, Male Connector, 5/16" Tube OD x 1/8" NPT Male, Pack of 2 : Industrial & Scientific Amazon.com: Legines Brass Inverted Flare Fitting,Brake Line Adapter, Male Connector, 5/16" Tube OD x 1/8" NPT Male, Pack of 2 : Industrial & Scientific
Old Mar 6, 2024 | 05:53 AM
You might also check your local hardware store or one of these suppliers.
https://www.mcmaster.com/
https://www.fastenal.com/
Old Mar 6, 2024 | 10:21 AM
ub2693v's Avatar
I have the fitting for the inlet side of the filter, its filter to carburetor that i need to figure out, there is a version of it on ebay but it states it is for a Carter carburetor. Maybe i'll take a trip to NAPA after work and see if they have something that may work. I was able to tap 1/8NPT on the inside of a flare nut but it leaves it very thin, i wouldn't trust it for the long run. The circled portion on the photo is what im looking for.
Old Mar 7, 2024 | 10:06 AM
ub2693v's Avatar
No luck finding the fitting, I used the inlet fitting from a junk carb, drilled it out, tapped to 1/4NPT and put in a 1/4" NPT male bushing with 1/8" NPT female threads inside, should be good to go.
Old Mar 8, 2024 | 10:12 AM
dsiaok's Avatar
Hi Guys, I lately bought an AC reproduction glass bowl gas clear out from Ecklers. When I established it these days on my rebuilt WCFB carburetor and started the motor it leaks at the bowl to frame seal. I attempted numerous attemps to reposition the bowl and tighten up the stem but the issue nonetheless leaks. Has anyone had the same trouble with those replica gasoline filters? I suppose the trouble is the rubber gasket isn't thick sufficient.
Tutuapp 9Apps
Old Mar 8, 2024 | 01:43 PM
madmax442.com's Avatar
madmax442.com
Yes, I had to make a gasket our of thicker "make a gasket" material. My seals were like mush. The ethanol in gas just destroys them. I am thinking paper style not rubber is the key.
350cuttyliteson
Oct 11, 2023 10:14 AM
Falkon
Apr 15, 2023 07:59 PM
NorthBay72supreme
Oct 5, 2022 07:53 AM
Cutdawg78
Apr 23, 2012 06:13 PM
BStone
Aug 13, 2011 06:16 AM
