1949 Thermostat removal
Old Mar 9, 2024 | 12:26 PM
57J2Olds's Avatar
Hello friends,
How do I remove the retaining ring to remove thermostat?
Never been out before.
Lee
Old Mar 9, 2024 | 01:01 PM
57J2Olds's Avatar
I got it apart.....can someone please tell me where I can get a thermostat for a 49 Olds 6 cyl?
Old Mar 9, 2024 | 02:08 PM
I cannot validate either via part number or experience whether this thermostat is correct for your vehicle other than description in the eBay post (below). Supposedly it fits the 257. You should continue to validate. Good Luck.
https://www.ebay.com/itm/30373742273...e%3AOldsmobile
Old Mar 9, 2024 | 02:18 PM
You can probably get one at your local auto parts store.
Old Mar 9, 2024 | 02:24 PM
Valid point, Eric. This particular thermostat fits a very large range of vehicles. Excellent chance you'd find one at a local auto parts store.
EDIT: BTW, I'll note you are supposed to use the ring from the thermostat when it was removed. If by chance the ring was damaged upon removal, be sure to get a replacement ring.
Old Mar 9, 2024 | 05:19 PM
Charlie Jones's Avatar
Phantom Phixer
My parts book shows that all Oldsmobiles took the same thermostat from 1941 thru 1959 .
Factory part numbers were 563311 for 180 degree and 563219 for 160 degree stats.
Auto parts stores may be able to cross reference those numbers .
Note there is no retainer ring , however, the recess where the stat fits must be free of rust.
Old Mar 10, 2024 | 08:27 AM
57J2Olds's Avatar
Charlie,
I found and NOS 180 degree online.....however not a 160. I have the Butterfly type.
Advantages or disadvantages of using 180 degree?
Lee
Old Mar 10, 2024 | 09:30 AM
Phantom Phixer
Originally Posted by 57J2Olds
Charlie,
Lee
180 degree is better for low usage , short trip use .
The modern type stat replaced the butterfly type many years ago.
It will work equally well in your application.
Old Mar 10, 2024 | 09:42 AM
57J2Olds's Avatar
ok Thanks !
Old Mar 10, 2024 | 12:22 PM
57J2Olds's Avatar
Charlie,
I found both now. Would I be better off with 160 for keeping my motor cooler in summer?
Thanks,
Lee
Old Mar 10, 2024 | 06:29 PM
Phantom Phixer
Charlie,
Thanks,
Lee
No, the higher temp will "cook off ' the condensation caused by combustion that gets in the oil.
This is especially important with short trips and infrequent use, Such as you would get in a collector car.
If the cooling system is in proper condition, a system with a 180 degree stat will not be any more likely to overheat than one with a 160 stat.
Old Mar 11, 2024 | 11:58 AM
madmax442.com's Avatar
madmax442.com
I agree, I put in a 160 stat and regretted it this winter, so another reason just to run a 180 stat.
Old Mar 11, 2024 | 12:26 PM
Sugar Bear's Avatar
Go with the 180, as Charlie said it will cook off moisture better. A properly operating thermostat only controls the minimum operating temperature, 180 isn't close to overheating.
Judging by the look of the thermostat and housing, the cooling needs to be cleaned. I'd suggest CRC ThermoCure and let it sit for a few days BUT it cannot be used with coolant only straight water so don't let it freeze.
Old Mar 11, 2024 | 12:45 PM
57J2Olds's Avatar
Thanks to all!!!
rickw30
May 18, 2025 11:29 AM
rickw30
Oct 20, 2023 02:00 AM
Kato_77
Paint
26
Jan 21, 2022 05:51 AM
tkcutlass
Aug 3, 2020 10:32 AM
442 Guatemala
Mar 16, 2010 04:31 PM
