engine paint
Old September 28th, 2009, 08:33 AM
50srocker's Avatar
engine paint
Where do you buy the correct engine paint for a 55 324 engine?
50srocker is offline
Old September 28th, 2009, 09:36 AM
Fusicks might carry it. You would be better off buying a POR 15 product to paint your engine, they only carry one "factory correct" Oldsmobile color; however, the paint quality is superior to any other paint. If you buy a $10 can of "factory correct" Oldsmobile spray paint it will just burn off 5 minutes after starting your engine the first time.
Olds64 is offline
Old September 28th, 2009, 05:40 PM
50srocker's Avatar
OK Thanks.
Old September 28th, 2009, 11:22 PM
Eightupman's Avatar
http://www.hirschauto.com/
$34 per qt. Late Oldsmobile Green All V-8 1949-1956
Eightupman is offline
Old September 29th, 2009, 10:31 AM
Dan Wirth's Avatar
Go to your local auto paint store. I have one in my area and they can order just about anything they don't have. The engine paints they have on hand, however, are limited in color. Some of the best (and most expensive) engine paints are made by POR15 - I've seen them in aluminum, red, black (called "Black Velvet" - a flat black, used it on my radiator, but needed thinning there). I don't remember seeing green, but wasn't interested in that color at the time.
Dan Wirth is offline
Jamesbo
Paint
June 13th, 2020 09:02 PM
jensenracing77
Paint
September 10th, 2014 02:33 PM
JpMotorsports
May 15th, 2014 07:08 AM
dlmsavings1
September 3rd, 2013 09:01 AM
805cut
May 3rd, 2012 08:11 PM
Quick Reply: engine paint
