Carb tools
Old Dec 28, 2022 | 12:11 PM
maineolds's Avatar
Carb tools
I've got a 1949 Olds 88 with a Rochester AA carb. The carb has an ID tag with numbers that match a 1950 model. Im looking for an original Borroughs Carburetor Tool. The kind mentioned in my 1949 service manual. It calls for a BT-17 to adjust the Choke rod, unloader, fast idle (AA 1949-50) marked. I found one but have since discovered a nearly identical tool is later known as the BT-35. It's listed for a 1950 Oldsmobile with Rochester AA carb. Id THINK since I have a carb from a 1950 go ahead and get the BT-35 but Im not sure because the only difference between the BT-17 and the BT-35 is a small wire on the tool. To add to the mystery, I can't find a use for that wire in my service manual. Does anyone know what the wire is used for? The other components of the tool are basically spacers to check gaps. I dont NEED this tool, but I like the thought of having an original tool when setting up the carb.
Here's some pics:
Old Jan 10, 2023 | 07:33 PM
vintagepne's Avatar
Try Vintage Auto Tools, https://vintageautotools.com , they have some of the carburetor tools and maybe able to answer your questions.
Old Jan 11, 2023 | 06:56 AM
Tedd Thompson's Avatar
The wire is probably to run/ clean the main jet, but that i just a guess...Tedd
skyhigh
Oct 12, 2020 10:27 AM
Skitch72
Oct 27, 2013 09:00 AM
Lady72nRob71
Oct 8, 2013 07:16 PM
John1963
Jul 20, 2012 02:29 PM
Southern_Hospitality
Jul 15, 2009 12:27 PM
