1948 / 49 Radiator Help
Old May 16, 2022 | 10:33 AM
57J2Olds's Avatar
Hello,
I took my 1948 (49 engine) radiator in to my local shop for diagnosis.
I need a new core and they quoted me $800.
They said they can make it aluminum ( $575), however not sure what I should do.
Looking for suggestions.
Old May 16, 2022 | 11:13 AM
New radiators have aluminum cores and plastic tanks. The only reason you shouldn't consider having the OE radiator recored with aluminum is if you are doing a concours restoration. Is the $800 quote to have it recored with copper & brass?
Old May 16, 2022 | 11:27 AM
57J2Olds's Avatar
I plan this for daily driver. No show car.
Yes, the $800 was for copper and brass.
Old Jan 16, 2023 | 04:56 PM
pclocksin's Avatar
i paid 175.00 for aluminum radiator on amazon, working good.
Old Jan 17, 2023 | 05:13 PM
coldwar's Avatar
Yeah there are all aluminum units and they are about the right size for these and intended for these vintage GM cars. They cool great owing to the heat transfer properties of AL -BUT- they work harden and crack pretty fast. And not just on the mountings, all over. $800 seems a wee bit high for a factory recore job, like $6-700 around here in Ohio. Lucky if you can find some one who has original Modine or Harrison heavy core material, a lot of shops use the stuff made in Mexico today which does work, but you can collapse the tubes with a thumbnail. Any of the newer units AL or CU fatigue fast if you hang a big heavy fan on the core, not supported from the sides.
Old Jan 21, 2023 | 01:41 PM
ub2693v's Avatar
I had my re-cored for my 1955 ‘98, I went OEM style because it’s an AC car and has the tabs for the fan shroud and the price between the two styles was not huge so I decided to make it look stock, not cheap that’s for sure, I did do some shopping around before I pulled the trigger, and champion radiators has a website and they give dimensions, there were at least 3-4 that would have fit with minimal modifications and less than 300$.
Dune67
Apr 9, 2021 08:17 AM
SanTan Devil
May 7, 2019 11:27 AM
The Flash
Ninety-Eight
Aug 6, 2017 09:01 AM
kitfoxdave
May 27, 2013 01:28 AM
parkerolds64
Jul 11, 2011 04:53 PM
