Can anyone tell me what brand booster this is?
Old Jul 9, 2018 | 01:37 PM
Rjharp's Avatar
Hi guys. I am going to do the disc brake conversion on my 58. Kanter needs to know what booster is on it. I know the picture isn’t great.
Old Jul 9, 2018 | 04:33 PM
Tedd Thompson's Avatar
Looks to be a Moraine if it is all cast iron. But It doesn't really mater because a Treadle-Vac will not support a modern disk brake system. Give this guy a call before you spend your money.... Tedd....http://www.discbrakemike.com
Old Jul 9, 2018 | 06:00 PM
Rjharp's Avatar
I will look into it Tedd. Thanks. They asked me if it was Bedix or Delco. They claim their booster and disc Assy is direct bolt on. Is it possible the vac from their system doesn’t use the treadle vac?
Old Jul 9, 2018 | 06:25 PM
As far as know 58's never came with a Delco master only Bendix and Moraine units. Someone correct me if I'm wrong but I'm pretty sure I'm correct on this.
I certainly would double check on this. I'm sure I would have herd if there was a easy conversion, this has been a issue for years on the mid fifties cars. Not only Oldsmobile's but many other makes of cars that used the Treadle Vac.
Most have to replace the swing peddle system move the new master to the firewall after bracing up the firewall with a plate or something so the action of the peddle is pushing in the correct direction for the new master to work. The treadle-Vac works A$$ backwards compared to the newer master booster combos. Check out Disk Brake Mike's web site. Good Information there.... Let us all know if I'm all wet on this, many would be happy if Kanter has something new on the market.... Tedd
Old Jul 9, 2018 | 06:49 PM
Rjharp's Avatar
I put a magnet against the master cylinder and it doesn’t stick. I would assume this means it’s a Bendix? I will do more research and ask more questions.
Old Aug 8, 2018 | 05:18 PM
Rjharp's Avatar
Kanter
Tedd thought I would post some pics for you. This is the booster Assy Kanter sent me. I hope it works.
Old Aug 9, 2018 | 08:38 AM
That is new to me, keep us posted on how it works. I'm very interested..... Tedd
Old Aug 9, 2018 | 12:56 PM
Sporty45's Avatar
Very nice looking, but where's the fluid reservoir? Does anybody make a MC setup like that for a 47?
Old Aug 9, 2018 | 01:18 PM
Rjharp's Avatar
There is a fluid resivoir also that you have to mount. I just didn’t take a picture of it. I will if you would like.
Old Aug 9, 2018 | 02:06 PM
Sporty45's Avatar
No, that's fine. I was just curious. I looked on Kanters site, and they list a complete disc setup for my 47 including MC, but they don't list just the MC setup. I already have the front discs because I swapped a whole front suspension in, but would love to know who makes just the MC setup for it!
Old Aug 9, 2018 | 02:29 PM
Rjharp's Avatar
They may. I would call them.
Old Aug 10, 2018 | 01:19 PM
TRWham's Avatar
As far as know 58's never came with a Delco master only Bendix and Moraine units. .... Tedd
Just a nomenclature issue I think. Delco presumably means Delco-Moraine, named for the Delco brake division in Moraine, OH (Dayton) at one time and one of many Delco divisions in Dayton. They made brake components there until Delco was spun into Delphi and sold off but I have lost track of where that business ended up (if it still exists).
Old Aug 10, 2018 | 05:46 PM
Thanks TRWham, a nice little piece of info to add to my over loaded memory. I like it when I learn something everyday.... Tedd
Old Jan 2, 2020 | 05:14 PM
ponder48's Avatar
1/02/2020 I just saw your posts about the brake boosters. How did the Kanter replacement work out for you? I'm having trouble with the rebuilt Bendix Treadle-vac on my 55 Olds.
Old Jan 2, 2020 | 05:22 PM
Rjharp's Avatar
It worked out well. A few minor issues. The calipers were rubbing slightly on the rims. Had to shave off an edge. They sent the wrong proportioning valve. And the brake light switch had to be modified. My friend owns a Transmission Shop and he did all the work for me but he said it wasn’t to bad. Overall it works well.
Old Jan 2, 2020 | 05:54 PM
ponder48's Avatar
Thanks.
Jay255
Apr 10, 2016 07:00 PM
geoff442
Feb 15, 2016 02:53 PM
Globeguy
Brakes/Hydraulic Systems
Apr 11, 2014 06:48 AM
plee3 64Olds
Apr 28, 2011 10:01 AM
Jamesbo
Jun 19, 2010 04:17 PM
