Balancer/Pulley Removal Tool for 55 324
Old Nov 25, 2019 | 05:55 AM
69Chrgr's Avatar
Can someone tell me what type of puller they used to remove the damper/pulley on a 324? It's on a 55 Olds 98.
Darren
Old Nov 25, 2019 | 07:29 AM
redoldsman's Avatar
Proud Viet Nam Veteran
You don't need a puller. Just remove the bolt in the center of the balancer and it should slide off the crank. It might take a little nudge but it is not pressed on.
Old Nov 25, 2019 | 07:43 AM
69Chrgr's Avatar
Thanks redoldsman!!
Old Nov 25, 2019 | 08:39 AM
Tedd Thompson's Avatar
What redoldsman said. I've pulled balancers off some real rust buckets with nothing more than a wrench and a rubber hammer.... Tedd
Old Nov 25, 2019 | 08:54 AM
69Chrgr's Avatar
Thanks for the heads up. These engines are a little older vintage than what I'm used to. The advice here is very valuable.
Old Jan 2, 2020 | 04:55 PM
ponder48's Avatar
Jan. 2, 2020 Did you get the balancer off ok? I had to tear my engine down a second time after rebuild because the machine shop had left out the oil gallery plugs that you find behind the cam gear. The balancer was stuck on because of the sealant I used following the shop manual instructions. I bored a hole in each of the 3 spokes in the balancer and tapped them to either 5/16 or 3/8. Then I was able to use a standard harmonic balancer puller available at NAPA.
Old Jan 2, 2020 | 10:24 PM
Ozzie's Avatar
As has been indicated, often the balancer comes off easily. The '55 Olds Shop Manual indicates the same, but says if it is stuck a gear puller can be used. Just don't pull on the ring.
Old Jan 3, 2020 | 06:19 AM
69Chrgr's Avatar
Yes sir, it was stuck so we had to make a puller and pull on the inner ring of pulley.
user 7408240824
Apr 1, 2019 03:07 PM
cmcdanl
Mar 22, 2019 09:01 AM
Dennis 55 olds
Feb 10, 2019 03:40 PM
Oldsragger
Jun 15, 2015 04:33 AM
Ihatefiberglass
Oct 20, 2014 07:39 PM
