all 56 owners ck in
'57 tri power
If anyone is looking, this seams pretty complete.
Gene
http://sfbay.craigslist.org/sfc/pts/3088308689.html
Gene
If anyone is interested in that tri-power setup I'm about 25 miles from Yankee Hill in fact I can see it from my back deck(one mountain top to another)I would be glad to take a look at it for you if you are serious about buying it ....Tedd
I was told at the 2011 Nationals by a gent who's 55 was in the senior class that he had researched the 55 super 88 convertibles and only 39 were registered in the US.Where he got this number is beyond me,I haven't found or heard of a service that offers that information but he seemed adamant on that number. Who knows, I just know not many 55 -56 Olds verts are around....Tedd
Damn few, but a educated guess would be about 1% survive after 50 years maybe a little more if it was a very popular model.
One of our fellow CO members needs our help. His wife just got sick and needs to sell his 56. If anybody knows anybody that wants a solid 56 give him this link.
Erit
http://cgi.ebay.com/ebaymotors/1956-...item2c67281ccf
Erit
Good morning 56 owners. Does anyone have a parts car? I need a couple parts for the drivers door on a 2 door hardtop and a piece of stainless for the right rear quarter panel. Let me know if anyone can help I am finally putting my 56 back together after paint.
Hey 56super88 What door parts and do you have pics of the mouldings you need.I have a box of mouldings and i think some are fromm a super but i am not sure ,i also have some misc.door parts what ones are you looking for.Glen
http://jmotes.deviantart.com/art/Dale-s-Whale-290715240
it's called Dale's Whale like Olds Dad said
I'm going to look in the shed this weekend to see if I have the parts you need
1956 324 Olds timing notch question
I am helping a friend straighten out a number on issues on a 56 Olds 98 he bought sight unseen on the internet. I read in the manual and it describes a
notch approx 1/4" long on the engine side of the pulley. I have rotated the pulley by hand 360 degrees several times and have not found this notch. The pointer is on the block so what am I missing here.
Thanks in advance.
Thanks in advance.
Citcapp, out of curiosity I went out and checked my 324 and could not find such timing marks eather but I did find a scribed line accross the pulley that was chalked that was used last time we timed the car...Tedd
Mine has a notch,i just replaced it recently.If your having timing issuse mabey its bad.Its hard to tell unless the ballancer is dangling.Mine would move in and out a bit by hand but not turn on the pulley by hand.This caused the timing to lag as the rpm went up and i thought it had a miss or dead cylinder.How many belt grooves do you have? i went from three to two as i only need one,i can take a pic of the old one tomorrow for you if you would like.Glen
Just a thought my harmonic balancer was rebuilt sometime ago I don't know if that would make a difference or not Also this is on a 55 Olds rather than a 56 but they should be the same as far as I know....Tedd
Pat
It's the notch seen on the iron ring, circled with a red box. Top edge as viewed installed is one limit, and the bottom is another. CAUTION the iron rings want to move on these engines, especially in hot rod use, and made worse if rubber is in bad shape. It's hard to tell from the camera angle, but the 1952 ring has moved almost an increment in the degree indication seen. You can find the mark way off even on low mileage cars, so if the performance or starting doesn't seem in line with what you see as your lead setting, check it out. CW
In the '56 balancer on the left, the heavy steel ring nearest the seal is not attached to the pulleys, and in mine, separation and clanging forced me to cut mine off and I never did find a replacement. I have to wonder just how effective it was in the first place...and especially slipping can only defeat its purpose. I wonder if there is an off the shelf replacement...something not too rare or overpriced. In hindsight, perhaps not destroying the ring and cleaning and refilling the rubber gap with silicone or something (on a bench) might have been an idea.....or maybe a bad one. unsure.
Let me note the 1952 is for power steering equipped cars. The single sheave pulley on non power equipped cars does NOT have a balancer ring, it is a simple yoked pulley, and some have a solid cupped pulley with six small ribs and again, no ring. The 1956 is the only 56 engine I have, now I cannot recall if they used the yoke or cupped pulley with no ring as late as 56. Maybe that is what citcapp has.
The pulley on the 324 in the 56 98 does not have the balancer ring but it does have the three belt grooves and no notch. I now believe this is not the original set up.
the 56 can be one ,two or three pulleys depending on the power options on the car.one for no power ,two for power steering and brakes ,three for power steering brakes and air conditioning.as i said i just replaced mine fusick can have them rebuilt,they also have some ready on the shelf.the balance rings were on all three of mine,single double and triple groved.The rings are vulcanized to the pulley and then balanced.Glen
Just installed a Rockport electric wiper kit in the 56 ... Yes, the bolt behind the motor is not possible to install. The stud and nut mentioned elsewhere on this site is a must-do.
The old cool air cleaner fits fine, the motor doesnt seem to stick out any farther than the vacuum motor did.
I know this is an old thread by I'm hoping someone may be subscribed who doesn't show up often anymore. If anyone with a 56 has a front license plate bracket, a trunk emblem for a 98 with the key latch in tact, or a 6 blade fan off an AC car that they are willing to sell please let me know I am interested! Thanks!
try this facebook group:
https://www.facebook.com/groups/54to56Olds/
i just got it home from usa too denmark
