59 Super 88 jack points
Old Jun 23, 2020 | 08:49 PM
DarrenOlds's Avatar
Hi,
I know the 1959 Super 88 is a variation on the x frame, so I want to see if anyone had an idea for the best places in the front and rear to jack it up and best places to position four jack stands to get underneath.
Thanks for your help,
Darren
Old Jun 24, 2020 | 06:01 AM
Billyaxe's Avatar
Can you still get the jack under the differential when there’s a sway bar there like on a 68 442? —Billy
Old Jun 24, 2020 | 06:10 AM
Schne442's Avatar
No it's not a parts car!!
To answer your question; Yes, if you use a 2" Rubber pad on your Jack pad you can center the Differential on the jack and clear the Sway-bar
Old Jun 24, 2020 | 06:12 AM
Darren, I moved your post to a new thread.
Old Jun 24, 2020 | 06:25 AM
DarrenOlds's Avatar
Differential stable?
The differential looks like something I have not seen before. On the x frame it looks to me a little under-supported. I could be wrong of course.
Also, what is the best place in the front, and where should I position the jack stands?
The help is really appreciated. I am thankful to have you guys.
Darren
Old Jun 25, 2020 | 06:53 AM
Tedd Thompson's Avatar
Never had a 59 but if it has a X frame any place on it should be hell for stout or on the frame rail edge..... Tedd
Old Jun 25, 2020 | 08:10 AM
DarrenOlds's Avatar
4 jacks
Just found the service manual. It says “When supporting car in a jack or floor stands the car should be supported at the suspension points only. Under no circumstances should the car be supported at the center of the “X” member or the extreme ends of the frame. It then has this picture (see diagram) I circled what I think are the probable points, numbering them 1-4 for the jacks. My question is if my 3 and 4 positions are correct?
Or do they mean by the differential and front crossmember?
Thanks!
Sugar Bear
May 21, 2020 05:03 PM
yeahbuddy
Oct 23, 2019 04:45 PM
PM70
Sep 9, 2019 07:34 AM
Mark57
Dec 4, 2016 04:47 PM
501Paratrooper
Feb 17, 2013 06:15 PM
