55 Olds Pitman Arm Spring
Old Nov 11, 2019 | 02:27 PM
69Chrgr's Avatar
Looking for spring that goes with pitman arm for 55 Olds 98.
Old Nov 12, 2019 | 06:13 AM
Ozzie's Avatar
That appears to be the same spring that was used between the relay rod and the tie rods and idler arm also. The group number is 6.888 and the part number is 264949. It was used from 1939 to 1958, at least. Unfortunately, I have no spares, nor do I know where to get one.
Old Nov 12, 2019 | 06:55 AM
I wonder if the Chevy versions are the same?
https://www.chevsofthe40s.com/shop/s...=KeywordSearch
Old Nov 12, 2019 | 01:31 PM
Tedd Thompson's Avatar
Probably not Chevy but maybe Buick or Pontianak. You could Google the part number and see if it comes up.....Tedd
Old Nov 13, 2019 | 06:43 AM
Ozzie's Avatar
The Chevy parts book doesn't show any group 6.888 or part number 264949. The only spring shown is group 6.876, which also shows in the Olds book, but is for the ends of the relay rod (which Chevy calls the steering connecting rod). On that there is a part number match between the 1939-1955 Olds and the 1953-1961 Corvette, but doesn't do much good as it is not the part needed. Apparently the Olds/Chevy designs were different. I don't have the Buick, Pontiac, or Cadillac parts books.
Old Nov 13, 2019 | 07:19 AM
69Chrgr's Avatar
Thanks guys. My customer had to buy a used Cadillac steering box assembly with pitman arm that has the correct spring attached. I believe Olds and Cadillac used same spring. Also, finally found a NOS turn signal harness assembly for the paltry sum of $425.00.
67abody
Jun 6, 2019 07:07 AM
Achti
Feb 15, 2017 10:51 AM
louie
Nov 18, 2013 10:35 AM
55coupe
Jul 10, 2012 08:07 PM
Brodyvonsickboy
Oct 15, 2009 10:59 AM
