55 Hydramatic "Improvement"
Old Nov 22, 2024 | 09:22 AM
54Rocket's Avatar
  • is this 1955 "improvement" ...discussed on a prior thread
  • on the 56 Hydramatic?
  • ie, I've got 2 in front of me : a 54 and a 56
  • which one should i have rebuilt ?
Old Nov 23, 2024 | 06:44 AM
madmax442.com's Avatar
madmax442.com
For what year engine and car? The Jetaway is the '56, they added Park, it's a different generation of the Hydramatic from the early fifties. A secondary fluid coupling was also added. The '54-'55 were tilted for clearance (called the slant pan). So, it depends what car you are putting it in and how original you want to keep it.
Old Nov 23, 2024 | 10:54 AM
madmax442.com
The '56 is a Hydramatic. The '54 and '55 are also Hydramatics. The '56 was a revised Hydramatic and they also called it the Jetaway.
Old Nov 23, 2024 | 03:36 PM
madmax442.com
Thumbs up
Cadillac called its four-speed 1956-65 version of the Controlled Coupling HydraMatic "Dual-Coupling HydraMatic". Pontiac called their 56-64 version "StratoFlight HydraMatic" and Olds called their 56-60 version "Jetaway HydraMatic". All the exact same transmission with different marketing names for the different Divisions. Maybe a slight difference in internals to get the desired shift and performance characteristics for the carline it was installed in.
Automatic-equipped 1956 Olds base 88s and Pontiac base Chieftains got the 1952-56 "Dual-Range HydraMatic" unless ordered with the new Controlled Coupling transmission.
Is that a better explanation?🙃
yes, you win!
Old Nov 23, 2024 | 03:49 PM
redoldsman's Avatar
Proud Viet Nam Veteran
The 54 and 56 are basically the same transmission. One difference is the rear tailshaft seal. My 54 had a 55 engine and transmission in it. I found that out when I had the transmission rebuilt. On the 55 the seal is actually up inside the tailshaft instead of being in the rear of the housing. If I had the pick between a 54 and 55, I would take the 54 in a minute.
Old Nov 26, 2024 | 04:43 AM
Wally's Avatar
Just a few things to note. Oldsmobile used the "1955" version of the original Hydramatic in most 1956 Oldsmobile 88s. These transmissions have a 1955 serial number on their tag. The 1956 Oldsmobile 98s and Super 88s should all have the Jetaway Hydramatic transmission.
Part of this was due to a fire at the Hydramatic transmission plant. The other part of this decision was to reduce the harshness of gear shifts. The Jetaway was designed to produce a softer gear shift.
A softer gear shift is produced by allowing more slip in the gear shift. This increased slip results in increased wear of the clutches and bands. The "luxury car market" desired a smoother/softer gear shift of the automatic transmission, thus the change to the Jetaway transmission.
Old Nov 26, 2024 | 08:17 AM
redoldsman's Avatar
Actually the hydramatic plant burned in 1953. Some 53 Olds and Cadillacs had Buick dynaflow transmissions and some Pontiacs had powerglides.
Old Nov 26, 2024 | 08:40 AM
Wally's Avatar
Thanks for correcting me, I am always willing to admit when I make a mistake. After doing some more research, the fire was one of the reasons for the redesign of the Hydra-Matic. The main reason was an effort to smooth the gear shifts.
Apparently I read something that said the fire was later and the main reason they changed production to the Jetaway.
Wally
Old Nov 26, 2024 | 09:50 AM
Charlie Jones's Avatar
Phantom Phixer
Here's a couple of pics of a '53 98 Holiday with a "Dynaflop" at OCA nats in Alburquerque in 2017.
Sounded like a motorboat when it took off from there.
fatback
Nov 26, 2024 04:56 AM
fatback
Aug 22, 2016 07:34 AM
burnout-dave
Nov 14, 2011 03:37 AM
hialeah56
Oct 25, 2009 06:02 PM
ashtons 56
Jun 24, 2009 04:33 AM
