1950 gas line?
Old April 11th, 2014, 09:04 AM
zeppigio's Avatar
1950 gas line?
does anyone know where I can buy a new steel gas line from the tank to fuel pump for my 50 olds 88 ? I have not found anything online, and how difficult is it on this year? also what is the best way to prime the carb on a original 303 rocket? thanks, any help is appreciated.
zeppigio is offline
Old April 11th, 2014, 10:53 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I doubt anybody makes the fuel lines simply because there is not enough demand. What you may have to do is use steel brake lines and a tubing bender. You will probably have to couple a few pieces together. That is a strange carb on the 50. I have shot starting fluid in it with the air cleaner off (be sure you have a fire extinguisher handy). I guess you could use something like a turkey baster and squirt it in the carb.
redoldsman is offline
Old April 11th, 2014, 11:10 AM
59-59-59's Avatar
That's easy- check out Inline Tube. They make them prebent for 1950 models
59-59-59 is offline
Old April 11th, 2014, 12:45 PM
zeppigio's Avatar
great thanks, ill check them out
zeppigio is offline
Del70
November 15th, 2013 02:24 PM
JackWolfram
March 25th, 2012 09:57 PM
davepnola
December 2nd, 2010 09:00 PM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: 1950 gas line?
