Won’t stay in Park
Old Sep 26, 2021 | 08:03 PM
RobT1970's Avatar
Won’t stay in Park
Hello,
I recently purchased a 1970 442 w/455 automatic floor mounted shift and it will not stay in park. If I really slam it home sometimes it will stay….maybe once out of 20 times I’m just wondering if anyone has had this same probables and if it is just an adjustment on the linkage underneath the car. Does anyone have pictures of what I may need to adjust?
Old Sep 26, 2021 | 09:28 PM
Devoking's Avatar
Do some research on "Parking Pawl".
Just a guess from your description, but that is where I would start.
Old Sep 26, 2021 | 09:39 PM
Sounds as if either the backdrive linkage from the transmission to the steering collar or the shifter cable itself needs to be adjusted.
I found the Dual Gate shifter takes a bit of trial and error to get adjusted correctly so it goes into first gear on the one end and Park on the other end of the travel.
evertl
May 26, 2020 01:01 PM
My2nd 69 442
Nov 18, 2018 02:41 PM
becerra66
Mar 1, 2015 11:15 AM
Wills72455
Aug 12, 2012 07:58 AM
1971viking
May 14, 2012 07:57 AM
