rear coil springs
Old Apr 25, 2014 | 06:05 PM
Chuxter's Avatar
1970 Cutlass Supreme
rear coil springs
Im not sure if this is the correct place to ask this but here goes. I've got a 1970 Cutlass supreme that came out factory with a 350 and I'm replacing that with a 455. The question is I'm replacing the rear coil springs in it and I'm not quite sure which ones to use, I see the ones for a 455 but also see the 442 springs. Which is the correct and what is the difference?
Old May 14, 2014 | 07:37 PM
442Classic's Avatar
Check out the Chassis Service Manual it will show you specific spring rates. You should also define what your trying to accomplish as far as handling goes and if you want to lower it some. I have a 71 442 and had PST replacement springs and it handled and rode ok, I then switched SC&C front and rear coil spring and it handles even better. A 540-660 lbs front and 137 lbs rear would work well too.
Bobac455
Jul 12, 2013 06:04 AM
Daniel2008
Apr 17, 2011 10:40 PM
Lady72nRob71
Aug 7, 2009 11:52 AM
cola
Jun 18, 2008 08:34 PM
