Rear coil springs for 1970 Cutlass
Old Oct 23, 2009 | 04:21 PM
Bobac455's Avatar
Hi,
I just bought a 1970 Cutlass Supreme (442 tribute) and the prior owner put station wagon springs in the rear. It has a posi "O" type rear. The back of the car sits way too high for me. I'm looking for the stock coil rear springs for this car. I know Eaton sells them new and I'm not sure buying used springs is a good idea. Can anyone help with a recommendation? If used ones are OK, I'd prefer to save the cash.
Anybody need good 1970 Vista Cruiser springs??
Old Oct 23, 2009 | 04:25 PM
Nilsson's Avatar
Go to Rock Auto on the net, they have them stock height and cheap.
Old Jul 11, 2013 | 05:29 PM
Markbgt01's Avatar
I talked to Mickey at Eaton, he said he'd send me a pair, MC1305 (which are a half inch lower than MC1233 (stock non HD)). I'm going to have him ship both, try them and keep the pair that looks best.
Very frustrating isn't it...
If you've found a set you like, let me know what and send me a picture...
thanks
Originally Posted by Bobac455
Hi,
Old Jul 11, 2013 | 07:37 PM
If you do search for "springs" on the site, we've had many conversations about suspension and springs, pictures and pn#s included. Then you'll just have to read the titles and research.
Old Jul 12, 2013 | 12:02 AM
wesste's Avatar
Hi!
Try Fusick!
www.fusick.com
Stefan
"Coil Springs and insulators:
Factory matched coil springs to restore proper ride height and handling. Our springs are made
specifically for your car, not generic springs others may offer at a lesser price. When ordering
we need to know model, body style, year, engine size, transmission, air conditioning, and if
heavy duty is desired.
note: heavy duty springs will result in a harsher ride than stock springs.
Springs are made to order and are not returnable. Allow 1-2 weeks delivery.
FCS612
Front Coil Springs 1961-77 all 165.00 pr.
RCS612
Rear Coil Springs 1961-77 all 165.00 pr.
RSi646
Rear Spring Insulator 1964-66 all 9.50 ea.
RSi612 Rear Spring Insulator 1967-75 all 9.50 ea."
Old Jul 12, 2013 | 03:59 AM
Markbgt01's Avatar
they get them from ESPO (I have them in the car).
I'm going to try Eaton... If this fails, I'll get a set that is dropped an inch or so... thanks. Just did an order with Fusick, they are my first choice for Olds parts
Originally Posted by wesste
Hi!
Try Fusick!
www.fusick.com
Stefan
heavy duty is desired. note: heavy duty springs will result in a harsher ride than stock springs.
FCS612
RCS612
RSi646
Old Jul 12, 2013 | 06:04 AM
RetroRanger's Avatar
72 Olds CS
Like old cutlass said check some prior threads search moog springs or goto rockauto see the options and then goto moogs site and see the specs.
I got the moog hd springs fr and rr w a rate that's near the fe2 rate the car sits perfectly level. I wanted it slightly higher in the rear so I added a 1" spacer it's now exactly how I wanted it
Btw they were about $150 for all four springs
https://classicoldsmobile.com/forums...tml#post539424
Here you go all the spring info you need to make an informed choice
Alex72cutty
Suspension & Handling
22
Apr 15, 2015 10:59 PM
Bobac455
Dec 4, 2013 10:03 AM
Bobac455
Jul 31, 2010 10:26 AM
cola
Jun 18, 2008 08:34 PM
