New Springs
New Springs
Hi THere
I own a 1970 olds Cutlass Supreme. Want to replace springs all the way around. Would like to raise the car slightly, but if not, a mild performance spring would be good. No intent to hot performance the car, other than headers maybe. Car has 47000 miles, just trying to give it a bit of a lift and a little more agressive stance.
Any suggestions on good springs, or good performance springs would be appreciated.
THanks in advance
Justa car guy
THanks in advance
Justa car guy
I have a 72 supreme. I put the moog HD springs on mine. they are similar to the fe2 spring rates and inexpensive at less than $200 for all four. I got them from rockauto if you search on here you will find the rockauto discount code and many others who have used the moogs
I also added a 1.25" fr sway bar and 1" rear bar at the same time as replacing the original springs on my car so the difference was night and day but not all due to the springs.
IIRC the fr spring was the 5450 and the rear was the 5385
EXCELLENT!!!!
Thanks for the reply. I came across exactly those springs and wondered about them, and they look like the ticket. I had also pondered sway bars for the car, and your reply answered that. See what you've done!!
Very much apprectiate the information.
Justa car guy
Some time back I asked for suggestions for front springs on the Olds e-mail list and got the following information:
> 5390 small block - no AC
> wire diameter = 0.650"
> load height = 11.000"
> load = 1952 pounds
> rate per inch = 336 pounds
> free height = 16.808"
> 5382 big block - no AC, small block - AC
> wire diameter = 0.660"
> load = 2066 pounds
> rate per inch = 360 pounds
> free height = 16.724"
> 5400 big block - AC
> load = 2167 pounds
> free height = 17.004"
> 5536 442 small block - AC - heavy duty, 442 big block - no AC - heavy duty
> wire diameter = 0.690"
> load = 1984 pounds
> rate per inch = 488 pounds
> free height = 15.063"
> 5450 small block - AC - heavy duty, big block - no AC - heavy duty, -442 big block - AC - heavy duty
> load height = 12.000"
> load = 1642 pounds
> rate per inch = 454 pounds
> free height = 15.616"
I picked the 5536s based on the higher spring rate and 1" lower ride height.
They are much stiffer (488 lbs/in) than the original springs, yet they give the same ride height as my worn out 34 year old originals. The data book showed the ride height to be 1" lower than the factory Cutlass/convertible springs - 11" vs 12". I researched the rear springs in the Moog data files and found the 442 rear spring applications are 1" lower, too, with higher spring rates than the "regular" cars. I do not really know the specs on my rear springs as I got them through PST a long, long time ago and they were advertised only as "442" springs. I think they are the equivalent of the Moog 5409 springs:
> All 442 applications
> wire diameter = 0.554"
> load height = 7.50"
> load = 847 pounds
> rate per inch = 143 pounds
> free height = 13.44"
Here's a side view showing how the car sits with the new springs:
It definitely sits lower than other Cutlasses. I was parked between another '71 convertible and a '70 at a recent show and my car was the lowest one in that lineup.
> load = 1952 pounds
> load = 2066 pounds
> 5400 big block - AC
> load = 2167 pounds
> load = 1984 pounds
> load = 1642 pounds
> load height = 7.50"
> load = 847 pounds
> load = 1952 pounds
> load = 2066 pounds
> 5400 big block - AC
> load = 2167 pounds
> load = 1984 pounds
> load = 1642 pounds
> load height = 7.50"
> load = 847 pounds
> load = 1952 pounds
> load = 2066 pounds
> 5400 big block - AC
> load = 2167 pounds
> load = 1984 pounds
> load = 1642 pounds
> load height = 7.50"
> load = 847 pounds
A fabulous looking convertible by the way.
They will definitely interchange. Perhaps there is some difference in vehicle weight between 70 and 71/72 that translates to different spring numbers.
The link below is moogs list of part numbers and technical details on thier springs. What you look for on the fronts are ID, load rate, length, and end type. This what I use to determine height and ride charactoristics compared to what the so called stock part numbers that had been recommended. You can sort this list by any column.
http://www.moog-suspension-parts.com...il_Springs.asp
bigjaythe1st
Suspension & Handling
May 8, 2012 05:45 PM
1acesmith
Aug 11, 2011 11:03 AM
