Is this a "O" posi carrier
Im looking at a carrier to buy it has 588 on the bottom but on top there no 588 to match but there is a BP cast and 1 stamped. It dose have the s spring. Is this a o Type carrier I know they sometimes didn't stamp the top
Thanks Scott
Thanks Scott
I don't think this is an O carrier. IIRC the O axle was a 12 bolt and this is clearly a 10 bolt.
I'd have to go look, but I think it is remarkably similar to my Series 2 posi for my 10 bolt.
Monzaz or 507OLDS can tell you for sure. They both build and sell differentials.
Monzaz is "Jim Mitschke" https://classicoldsmobile.com/forums...o=newpm&u=1632
507OLDS is 'Brian Trick" https://classicoldsmobile.com/forums...=newpm&u=25006
Ring and pinion
You're right; Brian confirmed that ^^^. I just looked at mine and the numbers on the carrier are 410408N, should be a 10 bolt carrier for 72.
Now my next question is which I should had ask what year is this for? Im going to use it for 68 442 and I know they used it from 67-70 and 71 was a different animal that cant be used for 67-70.
I didn't learn it or anything else overnight.
As for your clover problem,I have plenty of that too.I gotta treat it this weekend.It's the worst I have ever had it.I think it has a lot to due with the mild winter,and no freezing.More bugs,more spiders,crazy weeds,and plenty of everything else.
Ok got my posi today from Cali!! Very clean unit and the funny thing is that he didn't know what he had. I got it for $85 plus shipping!
So here my next question the ring is a 3.42 which I wanted but were to find the pinion? Any suggestions guys?
Thanks for all the help and advice!
Scott
Scott
Fyi
Scott
Scott
81 regency
April 21st, 2011 06:18 PM
aliensatemybuick
January 12th, 2009 09:25 AM
