‘67 th 400 other problem
Old Jun 24, 2012 | 05:42 AM
olds67's Avatar
Hi guys
my transmission have a problem,oil is ok, but the D and R not go.
I started to feel a buzz, with the pump, aspiring oil, gas when I gave the buzz grew and before long it was like the olds in N, the gears do not fit anymore.
What can be?
Old Jun 25, 2012 | 03:35 AM
olds67's Avatar
could be the torque conveter?
I mount a TH400 turbo idramatic,are all equal to Olds?
where can I find?
thanks!!!
Old Jun 26, 2012 | 08:26 AM
olds67's Avatar
is not nobody else who can help me?
Old Jun 26, 2012 | 08:35 AM
It can be a lot of different things, it may need a front pump to a complete rebuild. Transmissions, outside of a whine in low gear, should be relatively quiet.
Old Jun 26, 2012 | 10:17 AM
olds67's Avatar
complains in N.
If I insert the D or R, but disappears after a few minutes is not going the.
pressure is ok
Oil level ok
the pump works, I tried disconnecting the hoses and the oil comes out strong
thanks!!!!
Old Jun 27, 2012 | 09:07 AM
Ok, lets start over. If you put it in drive it makes noise and will not move the car? Same in reverse? The transmission fluid does not look or smell burnt, but a bright red/pink color?
When you check the fluid level with the engine warmed up and running in park, it's to the full mark on the dipstick?
Old Jun 27, 2012 | 01:01 PM
olds67's Avatar
when they are idle about 1000 rpm it feels like a buzz, much like the noise of the power steering pump, then I insert the D noise decreases and the Olds moves, if I repeat this a few times, stops and goes for a few minutes.
oil is red and clean
I checked the oil in N and the level is ok, he switched off the engine oil is more a sign that the pump works.
could be the converter? is the 67 I have not replaced
Old Jun 27, 2012 | 01:06 PM
Can the car be driven?
Old Jun 27, 2012 | 01:12 PM
olds67's Avatar
you can drive for a few minutes, then slide and if waiting a few minutes and then slide again and the noise there is always
Old Jun 27, 2012 | 04:52 PM
Is there anyone in the transmission business in Italy? I think you have problems, but it's hard to diagnose from here! If it's the original trans, then it probably is a switch pitch T400. Which means it has a variable vane torque converter. The actuating switch is on the throttle linkage near the firewall, it controlls the torque converter and has the kickdown switch built into it. It can be any number of things internal.
Old Jun 27, 2012 | 05:13 PM
TripDeuces's Avatar
Sounds like the converter from the symptoms you describe. Although the whine is usually the pump. Maybe a combination.
Old Jun 27, 2012 | 10:25 PM
olds67's Avatar
yes, there are workshops that deal with trasmission but the problem is that they want $ 2500 to get my hands on it.
I prefer to do, it will take me longer, but I prefer.
the switch next to the firewall is active.
the converter has more than forty years is the only thing that I have not changed..
Old Jun 27, 2012 | 10:26 PM
olds67's Avatar
I thought of a broken blade internal?
Old Jun 28, 2012 | 06:30 AM
Then I would start with the converter. You will need to either get your rebuilt, or get another switch pitch converter. Someone on here may have one. Post a request under parts wanted.
Old Jun 28, 2012 | 07:19 AM
olds67's Avatar
ok i try to insert your request.
thanks!!!! oldscutlass
the web I found this and it seems my problem
http://freeasestudyguides.com/a2_2.html
Old Jun 28, 2012 | 07:44 AM
Did you get your governer repaired the last time you had problems? If I remember correctly your gear was worn out.
Old Jun 28, 2012 | 02:00 PM
olds67's Avatar
The last time was the governor, and also that I had not put new and it broke.
Then I had a workshop.
now the converter.
I found one on ebay maybe it's better for my car
Old Jun 28, 2012 | 03:25 PM
Let us know how it turn out.
Old Jun 30, 2012 | 06:54 AM
olds67's Avatar
i check the oil pressur on the professional manometer
pressure in N-P 65 TO 70 is perfect
pressure in D 65 is perfect
pressure in S 70 minum is perfect
pressure in L 65 TO 70 is perfect
pressure in R 100 minum is perfect
the oil pump is OK!!!!
replaced the vacum modulator and the buzz is terminated!!!!!
The car started to move without slipping but not changed gear, so I opened the governor house and I found a nice surprise.
the governor was still broken in the same way as last time.
How can two governors in less than 500 miles?
both were used, this may be the cause?
I'm happy to have found the fault but I do not give a proper explanation.
Old Jul 3, 2012 | 01:03 PM
olds67's Avatar
mounted the new governor, the Olds is perfect!!!
Old Jul 3, 2012 | 04:49 PM
Wow 2 in 6 months!
Old Jul 4, 2012 | 01:03 PM
olds67's Avatar
were both old, the one I have mounted the second time was a TH400 in 79
Old Jul 4, 2012 | 03:38 PM
Hopefully this one does not eat itself, earlier I ruled that out as you had just repaired it. Glad you rechecked!
chrisneu68olds
Dec 30, 2011 10:17 AM
dgreen
Nov 6, 2011 09:40 AM
Gearhead442
Jan 27, 2011 03:03 AM
sbFALL63
Jan 23, 2011 09:01 AM
sbFALL63
May 28, 2010 05:45 AM
