What overdrive trans?
Old Jun 22, 2012 | 09:35 AM
sparky44268's Avatar
1968 442 vert resto-mod
Hi, Looking to install an over drive trans in my 68 442, 461cid, any advice would be appreciated.
Old Jun 22, 2012 | 10:32 AM
Mr442's Avatar
Is it a 4-speed or Auto? I installed a Gear Vendors OD in my 70 W-30 because I wanted to retain the OW Transmission. If I didn't have the OW, I might have gone with a built 200. If I remember correctly, the 700 has a high first gear.
Old Jun 22, 2012 | 10:54 AM
Right now there is a built T400 with shift kit and tci breakaway converter.
Old Jul 13, 2012 | 02:13 PM
Emreozd's Avatar
i have 455 which is rated at 475 hp at flywheel... i use a 12 bolt 2.73 rear end.. would you advice 200-4r Street fighter from TCI....
or should i choose 4L80e ... i prefer 200-4r since it is the same size with my current transmission (buffed up th350) and it is lightweight..
i live in turkey so i have one shot i'll import it from U.S.
anyone using 200-4r.. I use my car for mostly cruising. and some street racing..
KEVO35
Bravada
Dec 8, 2012 08:44 AM
skryla
Mar 2, 2011 08:01 AM
projectheaven
26
Aug 9, 2008 11:26 PM
72RocketPower
May 26, 2007 07:23 PM
72RocketPower
Drivetrain/Differentials
Jun 29, 2006 02:37 PM
