Gearing selection for trans/rear end?
Old Jul 13, 2012 | 04:18 AM
Zemanek889's Avatar
I'm currently in the process of starting my trans/rear end swap in my 72 cutlass. It has a SB 350 in it running somewhere just under 300hp(haven't dynoed it just a guess). My question is what gearing would be good for the trans and rear end. It will just be a cruiser not looking to race it just want to be Able to have some fun on cruise nights. Gas mileage is also not a concern. Thanks any advice is wanted and appreciated.
Old Jul 13, 2012 | 04:34 AM
Doc350s's Avatar
All depends on what you want to do I suppose. I swapped my one wheel peel with a posi unit and geared it up from 2.73 to 3.08. I've also got a 350 with a TH350. Should give me a little more off the line and still keep some highway driveability.
Old Jul 13, 2012 | 05:09 AM
ihengineer76's Avatar
What are you looking to do with this car? If it will see any strip time, you need to consider that. A final first gear ration of about 10:1 is optimum. To figure this out, you multiply the first gear ratio by you differential ratio. Are you going to run an overdrive transmission? If so then you can run a little shorter gear and still not be turning 4K at highway speed. If you have a 1:1 final trans ratio and are just street driving it, 3.42s are a good all around ratio. You also need to consider your cam specs. Just something to consider.
Tom
Old Jul 13, 2012 | 05:45 AM
bccan's Avatar
3.08 or 3.23 if you will do highway driving, a 3.42 would be nice if it is going to stay relatively local. In my experience & observation anything close to or over 3k @ 60 is traumatic for most anyone but the harder core.
Limited slip IMO is a must.
Old Jul 13, 2012 | 05:49 PM
ziff396's Avatar
I really like my 3.42's but granted, I stay local most of the time. However I run 28" tall tires in the rear which helps. And yes, just under 3 grand. We are spoiled nowdays with the overdrives. Back in the day 3 grand was nothing with 3.42's or 3.90's. Then add 4.11's!
Old Jul 14, 2012 | 05:02 PM
bccan's Avatar
When I was young & "harder core" I loved my big block 70 SS w/ 4.56, very short tires & M22, before that my 65 442 w/ 4.11 & M20 was a hoot!
When We put 3.08 in the red car to replace the 2.78/2.56, my kid came home distressed after his first ride on the highway!!! Now that we installed the 200-4R that spins about 1700-1800 @ 70 he is lovin life. Definitely an OD era child.
Definitely personal preference.
71Cutlass-S
Drivetrain/Differentials
21
May 3, 2020 06:39 AM
crjeeper
Nov 16, 2010 06:15 PM
1970_442
Jul 6, 2010 11:07 AM
procharged70cutlass
Dec 21, 2009 03:24 AM
jonstringer
May 24, 2008 12:45 AM
