Missing ZDDP - Zinc??
Old Apr 13, 2012 | 08:03 AM
Rickman48's Avatar
Just saw an add for Rislone - an 'additive' that restores the proper amount needed in older [flat tappet] engines!
4 to 1 on an oil change, probably great insurance!
Available everywhere, but didn't see a price.
Don't know if it's new, but I'll be looking for it on my next oil change!
Old Apr 13, 2012 | 08:05 AM
AZ455's Avatar
1974 DELTA 88
Sounds good to me, but do you know how much ZDDP in PPM you end up with when mixed with 4 quarts of oil?
Shell Rotella T 15w-40 has 1200 ppm as is off the shelf. Inexpensive, good oil in my opinion. Both my vehicles use it.
Old Apr 13, 2012 | 08:25 AM
garys 68's Avatar
Rotella T in all my flat tappet engines too.
Old Apr 13, 2012 | 09:01 AM
I use the rislone ZDDP additive, about $11.99 to 4 qts of oil. Been using it a year now.
Old Apr 13, 2012 | 10:00 AM
BILL DEMMER's Avatar
Just the facts...
i use gm EOS(the stuff they quit making). i add 1 oz per quart of oil, maybe a little more, in all my vehicles.
bill
Old Apr 13, 2012 | 10:05 AM
Kaline's Avatar
Instead of an additive, I use Kendall GT-1 High Performance motor oil in my flat tappet engines. It is designed for flat-tappet cams and has higher levels of ZDDP. I have used it in my high-performance air-cooled Volkswagen (high compression, high lift cam) since 2004 with no issues (6,600 miles to date).
Dan Wirth
Jun 17, 2019 12:08 PM
Longhorncutlass
Jan 6, 2014 05:51 PM
oldcutlass
Apr 21, 2012 10:10 AM
ent72olds
Feb 6, 2012 05:06 PM
gearheads78
Jan 27, 2009 01:09 PM
