Crossmember Insulator advice requested
Old Aug 8, 2012 | 05:41 PM
71Convertible's Avatar
Question Crossmember Insulator advice requested
In the power train rebuild of my 71 Cutlass Supreme convertible, I've removed the transmission support crossmember. It didn't have insulators where it attaches to the frame rails. The crossmember was bolted directly to the frame rails. The '71 AIM doen't show that the original assembly included insulators, however I see that insulators are available, so I'd like to ask for advice from those who may have experience with them. Does this affect the alignment of the transmission and drivesaft? If added, I'm guessing that different bolts will be needed. Any experience or opinion is welcome.
Thanks,
Don
71Convertible
Old Aug 8, 2012 | 06:00 PM
Run to Rund's Avatar
Bolt it directly per OEM.
Old Aug 8, 2012 | 09:53 PM
BILL DEMMER's Avatar
Just the facts...
X2
bill
Old Aug 9, 2012 | 09:02 AM
Your Advice
Thank you, that is what I will do.
Don
71Convertible
Old Aug 9, 2012 | 10:47 AM
442_1972's Avatar
Pontiac and Buick used the insulators, but Olds and Chevy did not. I'm not sure why there was a difference between the manufacturers, but that's what I've seen. The ends of the crossmembers that have insulators are slightly different than the ends of the crossmembers that bolt directly to the frame.
Tedd Thompson
May 1, 2013 09:11 PM
81 regency
Apr 10, 2011 05:15 PM
oldsca
Aug 16, 2010 04:50 PM
scott_442
May 16, 2009 08:55 PM
chip888
Jul 29, 2008 06:16 PM
